SDE 9.2 - Libs
Howard Butler
hobu.inc at GMAIL.COM
Thu Aug 2 10:50:12 EDT 2007
Johannes,
I believe you need to use --with-sde=[PATH]/sdeexe92 --with-sde-
version=92
You must have the ArcSDE Client SDK installed, which has the include
files and libraries to link against.
ESRI changed their library layout in 9.2, and if I recall correctly,
MapServer's configure logic is able to handle it when given --with-
sde-version=92.
Howard
On Aug 2, 2007, at 8:15 AM, Hr. Johannes Loose wrote:
> Hello List
> I am trying to compile mapserver 4.10.2 with ArcSDE 9.2 support.
> Compiling has worked fine for SDE 9.1 using the sdeexe91 tree
> (including sdetype.h /
> libsde91.a / libsde91.so). The sdeexe92 tree does NOT contain the
> files sdetype.h,
> libsde92.a, libsde92.so. Hence the configure script is not able to
> find that files and prints out
> the related error. The flags i used for the configure script are: --
> with-sde-version=92 --with-
> sderaster --with-sde=[PATH]/sdeexe92/lib
> How can this be fixed?
> Thanks in advance for any helping reply :-)
> Johannes Loose
