Status of RFC 31
Sean Gillies
sgillies at FRII.COM
Wed Aug 8 16:21:13 EDT 2007
Steve Lime wrote:
> It's basically done (except for the URLPATTERN , rats) but needs testing and some documentation of course. I added "updateFromString()" methods
> to all mapscript objects. The string loader for a mapfile only exists as a direct call to msLoadMapFromString, I didn't change the constructor for a mapObj,
> not sure how that would work.
>>> map = mapscript.fromstring("""MAP ... END""")
that seems pretty simple. It would be good enough for 5.0 if this always
returned a mapObj or raised an exception. Later, you could add logic to
let it create layers or others.
> Stuff "todo":
> - figure out how to deal with msLoadMapFromString
What do you mean by how to deal?
> - update PHP/MapScript with the updateFromString methods (will create a bug)
> - create a documentation bug
> - develop some test cases
> Any help appreciated...
> Steve
I already committed one test, and will add more.
Cheers,
Sean
