AGG changes for MapScript maintainers
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Sun Aug 12 13:02:22 EDT 2007
I've checked (only static analysis, I don't have code to run
unfortunately) and both Java and Ruby seem OK as long as the gdBuffer
typemap works as before.
Umberto
On 8/12/07, Howard Butler <hobu.inc at gmail.com> wrote:
> Language-specific MapScript typemaps or specializations need to be
> updated to not exclusively use MapServer GD functions. Previously,
> the default implementation of getBytes in image.i did:
> buffer.data = msSaveImageBufferGD(self->img.gd, &buffer.size, self-
> >format);
> Additionally, there is now an if test to check for the presence of an
> AGG driver and use the corresponding method to get the image buffer.
> If your MapScript language just uses getBytes for all of its buffer/
> image handling (other than the image.save() method which does not
> require any swig interface changes), you should be ok. If you
> MapScript language has overrides or %extends of imageObj's methods,
> they will need to be updated to do the following in the case of an
> AGG format:
> buffer.data = msSaveImageBufferAGG(self->img.gd, &buffer.size, self-
> >format);
> I have updated some of the Python extensions (I do not have its
> image.write() done yet for AGG), and a quick browse showed at least
> C# with some overrides that need to be updated. Java and Ruby too?
> Hopefully we can the necessary changes in before the next beta as
> more folks start testing MapServer 5.0 to make pretty pictures :)
> Howard
