Motion: include AGG freetype (2.4 version) in MapServer
Daniel Morissette
dmorissette at MAPGEARS.COM
Tue Aug 14 10:13:28 EDT 2007
For what it's worth I'm +0 on this at this point... I may change my mind
once I start going through the hell of trying to build AGG support on
various platforms, but I have not been able to get to that yet and still
have some hope that someone will come up with a way to solve this issue
in a way that avoids having to include this code in the source tree.
Daniel
Howard Butler wrote:
>>> All,
>>> I've come around to thinking that the only way we can limit the
>>> configuration/building issues we are about to inflict on our users
>>> with AGG is to include the freetype stuff in MapServer's source. It
>>> seems many of the distros are treating the AGG freetype
>>> inconsistently. Just building AGG because of its spartan build
>>> setup is quite a chore. Hacking makefiles, compile targets, and
>>> link lines to get what is needed is just too much.
>>> I propose we take the GDAL "thirdparty" approach and put the AGG
>>> freetype stuff in ./thirdparty/agg and update MapServer's configure/
>>> make system to always use that. We have done something similar in
>>> the past with GD, right? If so, this approach would not be
>>> unprecedented.
>>> Howard
>> I disagree. One of the tenets of Open Source is that people
>> collaborate on software and fork only as a last resort. Why not
>> contribute improvements to AntiGrain? I thought I read that the author
>> was going to grant a GPL exception explicitly to MapServer.
> Someone please correct me if I am wrong, but my reasoning for this
> motion is as follows:
> - AGG will never be mainlining the freetype stuff because it doesn't
> want it as a default dependency
> - The AGG author doesn't want to use autoconf/libtool, so patches that
> we might submit to make building things with options more easy are
> likely to rejected.
> - AGG's license split (and ambiguity with respect to MapServer
> specifically) and MapServer's usage where GPL isn't appropriate means
> we'll have a not insignificant number of people continuing to use AGG
> 2.4, where patches like this, even if accepted, would not apply to them.
> - It is a lesser evil (in terms of work required and badwill generated)
> to just maintain a small copy of the freetype stuff than to fork *all*
> of AGG at 2.4. Some other group may yet do this (I have no direct
> knowledge). It almost happened a number of times with libgd before
> Boutell let PHP pick it up.
> Howard
Daniel Morissette
http://www.mapgears.com/
