agg changes
thomas bonfort
thomas.bonfort at GMAIL.COM
Thu Aug 30 10:14:02 EDT 2007
daniel,
maybe a solution could be to mark those features as deprecated in the
doc, and that they will not be maintained anymore and removed in a
future (which one?) release.
thomas
On 8/30/07, Daniel Morissette <dmorissette at mapgears.com> wrote:
> Paul,
> Unfortunately at a few days from the release I think it's too late to
> strip out stuff. Your reasoning makes sense, but in the interest of
> getting a release out I have to say "no more changes in 5.0".
> Daniel
> Paul Spencer wrote:
> > Steve,
> > I'd like to suggest defering cartographic enhancements (by which I mean
> > additional keywords in the map file to specify more advanced
> > cartographic options) until post 5.0. I think, since you are moving
> > from 4.x to 5.x and *can* make some changes that are not necessarily
> > backwards compatible, that you should consider removing things from the
> > mapfile at this point that don't work or won't be supported in order to
> > establish a minimum baseline which the 5.x series can build on by adding
> > new features without having to make an incompatible change in the next
> > version. Essentially, I am advocating stripping out as much as
> > possible/practical, and then adding new stuff post 5.0.
> > Looking forward to 5.2, I think it would be really beneficial to start a
> > dialog with the user community on cartographic needs and try to
> > establish a set of requirements that can be built towards in the 5.x
> > series. I know that MapGuide has implemented point and line support for
> > a massive USGS cartographic standard and has some very impressive demos
> > of the new cartography. There is also a large document describing the
> > cartographic needs of the Canadian national dataset folks. There are
> > probably other 'standards' out there too.
> > AGG has given mapserver an excellent foundation to build on for premium
> > cartography, and I think it would be a mistake to leave stuff in
> > mapserver 5.0 that we may regret post 5.0.
> > Cheers
> > Paul
> > |Paul Spencer pspencer at dmsolutions.ca |
> > |Chief Technology Officer |
> > |DM Solutions Group Inc http://www.dmsolutions.ca/ |
> Daniel Morissette
> http://www.mapgears.com/
