svn build error...
Frank Warmerdam
warmerdam at POBOX.COM
Wed Dec 19 11:39:22 EST 2007
Steve Lime wrote:
> I tried rebuilding everything, new configure, etc... An error keeps popping up:
> g++ -c -O2 -fPIC -Wall -DHAVE_VSNPRINTF -DNEED_STRLCAT -DUSE_WMS_LYR -DUSE_LIBXML2 -DUSE_CURL -DUSE_WCS_SVR -DUSE_WFS_SVR -DUSE_WMS_SVR -DUSE_ORACLESPATIAL -DUSE_POSTGIS -DUSE_GDAL -DUSE_OGR -DUSE_GEOS -DUSE_SDE -DUSE_PROJ -DUSE_EPPL -DUSE_AGG -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DGD_HAS_FTEX_XSHOW -DGD_HAS_GDIMAGEGIFPTR -DGD_HAS_GETBITMAPFONTS -DUSE_ICONV -DUSE_ZLIB -I/usr/include -I/usr/local/src/agg-2.4/include -I/usr/local/src/agg-2.4/font_freetype -I/usr/include/freetype2 -I/usr/local/include -I/usr/local/esri/sdeexe91/include -I/usr/local/include -I/usr/local/pgsql/include -I/usr/include/oracle/10.2.0.1/client -I/usr/rdbms/demo -I/usr/rdbms/public -I/usr/local/include -I/usr/include/libxml2 mapogr.cpp -o mapogr.o
> mapogr.cpp: In function `int msOGRFileWhichShapes(layerObj*, rectObj,
> msOGRFileInfo*)':
> mapogr.cpp:1080: error: `OGR_G_AddPoint_2D' undeclared (first use this
> function)
> mapogr.cpp:1080: error: (Each undeclared identifier is reported only once for
> each function it appears in.)
> mapogr.cpp: In function `void msOGRCleanup()':
> mapogr.cpp:2685: error: `OGRCleanupAll' undeclared (first use this function)
> make: *** [mapogr.o] Error 1
Steve,
It would appear you are using a fairly antique GDAL and that these functions
exist only in more modern ones. I'll take a crack at making them version
conditional and you can confirm if my changes do the trick.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
