Non-clipped polygon annotation
Shawn Gervais
project10 at PROJECT10.NET
Wed Dec 19 13:38:55 EST 2007
Steve Lime wrote:
> You tried running msPolygonLabelPoint() on the raw shape then? What was the issue?
Yeah, I tried this sequence:
- msPolygonLabelPoint() on the unadulterated shape. While it did not
error, it produced a label point that was not correct.
- msClipShape(), msTransformShape() as normal
What I ended up needing to do, to get msPolygonLabelPoint to produce an
annopoint that was within my visible bbox, was:
- msTransformShape()
- .. but now I can't run msClipShape() as that mangles the shape (my
polys were reduced to 0 numlines)
So you can see my problem -- I can't get the label point for a shape
before transforming it, but I can't transform it before clipping it lest
I destroy the shape.
-Shawn
