WFS 1.1
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Tue Feb 6 15:40:25 EST 2007
> -----Original Message-----
> From: Bart van den Eijnden (OSGIS) [mailto:bartvde at osgis.nl]
> Sent: 06 February, 2007 3:31 PM
> To: Kralidis,Tom [Burlington]
> Cc: MAPSERVER-DEV at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-DEV] WFS 1.1
> Hi Tom,
> I think this is a good analysis, it shows you're more
> familiar with the
> 1.1 spec than me :-)
> I think the major thing is to get a proper WFS 1.1
> GetCapabilities in there.
> Wrt the SRSNAME parameter, I believe Mapserver can already
> reproject as a WFS, but ofcourse this is now setup using
> METADATA (wfs_srs).
Right. This would involve MapServer being able to reproject based on
client request, like WMS does with SRS, i.e.:
http://host/t?service=WFS&version=1.1.0&request=GetFeature&typename=foo&
srs=EPSG:42304
> MAXFEATURES is already in Mapserver WFS 1.0 AFAIK, but it
> only gets evaluated after all the data has been retrieved ....
Yes, it's available from the .map file configuration end? I was
referring to the client being able to pass, i.e.:
maxfeatures=8
...which, AFAIK, is not currently supported.
> Best regards,
> Bart
> Kralidis,Tom [Burlington] schreef:
> >> is anybody planning on adding WFS 1.1 to Mapserver WFS? GML3 is in
> >> place, I've verified it can be read by ArcGIS 9.2 as a GML
> file, so
> >> we are missing a large potential market because we don't
> support WFS
> >> 1.1 (ArcGIS only supports WFS 1.1 and not 1.0).
> >> I am thinking of only adding a 1.1 GetCapabilities
> interface, not any
> >> of the new operations of WFS 1.1. GetFeature for 1.1 can
> default to
> >> OUTPUTFORMAT=GML3.
> > So, based on above, the differences in a MapServer OGC:WFS
> 1.1.0 impl
> > would be
> > GetCapabilities
> > - response: an OGC:WFS 1.1.0 style Capabilities document. The big
> > difference is the OGC OWS Common adherence. Note that, now that we
> > have mapowscommon.c, we can leverage this on output, as it supports
> > most of the constructs already
> > - do we support the (optional) AcceptFormats, AcceptVersions and
> > Sections Keywords of this request, which are not covered by
> WFS 1.0.0?
> > Note that, if we do, we will want to abstract them to
> mapowscommon.c,
> > as this is the MO of forthcoming OGC interface specs
> > - where possible, MIME types: now have to be communicated as
> > mime_type; subtype (i.e. <Value>text/xml; subtype=gml/3.1.1</Value>
> > DescribeFeatureType
> > - REQUIRES a GML3 output (which we already support)
> > - output format MIME type: text/xml; subtype=gml/3.1.1 MUST be
> > supported. Other additional formats are allowed
> > GetFeature
> > - optional SRSNAME parameter now allowed, which allows for
> one to ask
> > for data in a given SRS (hence reprojection). Would be helpful
> > - optional allow the WFS client to set MAXFEATURES value (which
> > could/would override the MAP/WEB/METADATA/wfs_maxfeatures, if the
> > value is LOWER)
> > - optional allow the WFS client to send SORTBY parameter would be
> > useful for sorting results on response
> > Note: this analysis omits OPTIONAL features which I think are not
> > worth implementing, etc.
> > Other comments here w.r.t implementation?
> >> I would be willing to help out with it.
> >> Anybody interested in helping out?
> OSGIS, Open Source GIS
> bartvde at osgis.nl
> http://www.osgis.nl
