Compile Errors - Mapserver 4.10.0 and Regex 0.12
Dewald Troskie
dewald at GLOBALIMAGE.CO.ZA
Wed Feb 7 06:00:38 EST 2007
I am trying to compile Mapserver 4.10.0 under VC 2005 (.NET 2.0) on Windows
XP SP2. I have managed to sort out most of the compilation errrors (GD
related libraries, despite using the precompiled bgd.lib stub), but keep
getting these Regex errors. I am new to C / C++ so I need help.
I am using to stock regex library from GNU.org, and have tried the GnuWin
Regex Library, as well as thew Boost C++ regex library. Is it the VC8
non-standard "safe" C++ compiler? I don't know where to go from here. I am
following the documentation / Win32 Compile howto from the UMN Mapserver
site. Is it maybe also the crtdefs.c include causing problems, and if so
what is the workaround.
Below is the output from the compile nmake /f makefile.vc for Mapserver:
C:\projects\mapserver-4.10.0>nmake /f makefile.vc
Microsoft (R) Program Maintenance Utility Version 8.00.50727.42
Copyright (C) Microsoft Corporation. All rights reserved.
cl /nologo /Zi /MD /W3 /DDEBUG /EHsc /D_CRT_SECURE_NO_DEPRECATE /D_CRT_N
ONSTDC_NO_DEPRECATE -Ic:\projects\gdwin32 -Ic:\projects\jpeg-6b -Ic:\projects
\proj-4.5.0/src -Ic:\projects\regex-0.12 -Ic:\projects\gdal-1.4.0/gcore -Ic:\pro
jects\gdal-1.4.0/alg -Ic:\projects\gdal-1.4.0/ogr -Ic:\projects\gdal-1.4.0/port
-Ic:\projects\zlib-1.2.3 -DHAVE_STRING_H -DREGEX_MALLOC -DNEED_ST
RCASECMP -DNEED_STRNCASECMP -DNEED_STRLCAT -DUSE_PROJ -DUSE_PROJ_API_H -DUSE
_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_GIF -DGD_HAS_GDIMAGEGIFP
TR -DUSE_GD_FT -DGD_HAS_GETBITMAPFONT -DGD_HAS_FTEX_XSHOW -DUSE_WMS_SVR -DUSE_T
HREAD -DIGNORE_MISSING_DATA -DENABLE_STDERR_DEBUG -DUSE_GDAL -DUS
E_GD_ANTIALIAS -DUSE_ZLIB -DWIN32 -D_WIN32 /c c:\projects\regex-0.12\rege
x.c /Foc:\projects\regex-0.12\regex.obj
regex.c
c:\projects\regex-0.12\regex.c(768) : warning C4018: '<' : signed/unsigned misma
tch
c:\projects\regex-0.12\regex.c(774) : warning C4018: '<' : signed/unsigned misma
tch
c:\projects\regex-0.12\regex.c(1123) : warning C4018: '<' : signed/unsigned mism
atch
c:\projects\regex-0.12\regex.c(1189) : warning C4018: '>' : signed/unsigned mism
atch
c:\projects\regex-0.12\regex.c(1204) : warning C4018: '>' : signed/unsigned mism
atch
c:\projects\regex-0.12\regex.c(1297) : warning C4018: '>' : signed/unsigned mism
atch
c:\projects\regex-0.12\regex.c(1322) : warning C4018: '>' : signed/unsigned mism
atch
c:\projects\regex-0.12\regex.c(1336) : warning C4018: '>' : signed/unsigned mism
atch
c:\projects\regex-0.12\regex.c(1346) : warning C4018: '>' : signed/unsigned mism
atch
c:\projects\regex-0.12\regex.c(1358) : warning C4018: '>' : signed/unsigned mism
atch
c:\projects\regex-0.12\regex.c(1364) : warning C4018: '>' : signed/unsigned mism
atch
c:\projects\regex-0.12\regex.c(1372) : warning C4018: '>' : signed/unsigned mism
atch
c:\projects\regex-0.12\regex.c(1608) : warning C4018: '>' : signed/unsigned mism
atch
c:\projects\regex-0.12\regex.c(1638) : warning C4018: '>' : signed/unsigned mism
atch
c:\projects\regex-0.12\regex.c(1683) : warning C4018: '>' : signed/unsigned mism
atch
c:\projects\regex-0.12\regex.c(1698) : warning C4018: '>' : signed/unsigned mism
atch
c:\projects\regex-0.12\regex.c(1726) : warning C4018: '>' : signed/unsigned mism
atch
c:\projects\regex-0.12\regex.c(1813) : warning C4018: '>' : signed/unsigned mism
atch
c:\projects\regex-0.12\regex.c(1926) : warning C4018: '>' : signed/unsigned mism
atch
c:\projects\regex-0.12\regex.c(1932) : warning C4018: '>' : signed/unsigned mism
atch
c:\projects\regex-0.12\regex.c(1937) : warning C4018: '>' : signed/unsigned mism
atch
c:\projects\regex-0.12\regex.c(1941) : warning C4018: '>' : signed/unsigned mism
atch
c:\projects\regex-0.12\regex.c(1945) : warning C4018: '>' : signed/unsigned mism
atch
c:\projects\regex-0.12\regex.c(1949) : warning C4018: '>' : signed/unsigned mism
atch
c:\projects\regex-0.12\regex.c(1953) : warning C4018: '>' : signed/unsigned mism
atch
c:\projects\regex-0.12\regex.c(1957) : warning C4018: '>' : signed/unsigned mism
atch
c:\projects\regex-0.12\regex.c(1975) : warning C4018: '>' : signed/unsigned mism
atch
c:\projects\regex-0.12\regex.c(2023) : warning C4018: '>' : signed/unsigned mism
atch
c:\projects\regex-0.12\regex.c(2027) : warning C4018: '>' : signed/unsigned mism
atch
c:\projects\regex-0.12\regex.c(2042) : warning C4013: 'free' undefined; assuming
extern returning int
c:\projects\regex-0.12\regex.c(2236) : warning C4018: '<=' : signed/unsigned mis
match
c:\projects\regex-0.12\regex.c(2784) : warning C4013: 'abort' undefined; assumin
g extern returning int
c:\projects\regex-0.12\regex.c(2834) : warning C4047: '=' : 'regoff_t *' differs
in levels of indirection from 'int'
c:\projects\regex-0.12\regex.c(3313) : warning C4018: '<' : signed/unsigned mism
atch
c:\projects\regex-0.12\regex.c(3403) : warning C4018: '<' : signed/unsigned mism
atch
c:\projects\regex-0.12\regex.c(3427) : warning C4018: '<' : signed/unsigned mism
atch
c:\projects\regex-0.12\regex.c(3480) : warning C4018: '<' : signed/unsigned mism
atch
c:\projects\regex-0.12\regex.c(3496) : warning C4018: '<' : signed/unsigned mism
atch
c:\projects\regex-0.12\regex.c(3760) : warning C4018: '<' : signed/unsigned mism
atch
c:\projects\regex-0.12\regex.c(3771) : warning C4018: '<=' : signed/unsigned mis
match
c:\projects\regex-0.12\regex.c(3918) : warning C4018: '<=' : signed/unsigned mis
match
c:\projects\regex-0.12\regex.c(3971) : warning C4018: '<=' : signed/unsigned mis
match
c:\projects\regex-0.12\regex.c(4079) : warning C4018: '>=' : signed/unsigned mis
match
c:\projects\regex-0.12\regex.c(4110) : warning C4018: '<=' : signed/unsigned mis
match
c:\projects\regex-0.12\regex.c(4123) : warning C4018: '<=' : signed/unsigned mis
match
c:\projects\regex-0.12\regex.c(4293) : warning C4018: '>=' : signed/unsigned mis
match
c:\projects\regex-0.12\regex.c(3771) : warning C4101: 'destination' : unreferenc
ed local variable
c:\projects\regex-0.12\regex.c(3918) : warning C4101: 'destination' : unreferenc
ed local variable
c:\projects\regex-0.12\regex.c(3971) : warning C4101: 'destination' : unreferenc
ed local variable
c:\projects\regex-0.12\regex.c(4110) : warning C4101: 'destination' : unreferenc
ed local variable
c:\projects\regex-0.12\regex.c(4123) : warning C4101: 'destination' : unreferenc
ed local variable
c:\projects\regex-0.12\regex.c(4876) : warning C4996: 'errcode' was declared dep
recated
C:\Program Files\Microsoft Visual Studio 8\VC\INCLUDE\crtdefs.h(506) : s
ee declaration of 'errcode'
Message: 'This name was supported during some Whidbey pre-releases. Inst
ead, use the standard name errno_t.'
c:\projects\regex-0.12\regex.c(4876) : error C2081: 'preg' : name in formal para
meter list illegal
c:\projects\regex-0.12\regex.c(4876) : error C2081: 'errbuf' : name in formal pa
rameter list illegal
c:\projects\regex-0.12\regex.c(4876) : error C2081: 'errbuf_size' : name in form
al parameter list illegal
c:\projects\regex-0.12\regex.c(4877) : error C2055: expected formal parameter li
st, not a type list
c:\projects\regex-0.12\regex.c(4877) : error C2082: redefinition of formal param
eter 'errcode'
c:\projects\regex-0.12\regex.c(4885) : warning C4996: 'errcode' was declared dep
recated
c:\projects\regex-0.12\regex.c(4885) : error C2059: syntax error : 'type'
c:\projects\regex-0.12\regex.c(4893) : error C2275: 'errcode' : illegal use of t
his type as an expression
NMAKE : fatal error U1077: '"C:\Program Files\Microsoft Visual Studio 8\VC\BIN\c
l.EXE"' : return code '0x2'
Stop.
Thanks in advance,
Dewald Troskie
GIS Developer / Database Architect
Network Administrator
GIS Global Image (Pty) Ltd.
Helping the world make informed decisions
P.O Box 15 The Innovation Hub 0087
Cell: +27 (0)82 615 0248
Tel: +27 (0)12 844 0660
Fax: +27 (0)86 619 3958
Email: dewald at globalimage.co.za
Web: www.globalimage.co.za
Web: www.mapme.co.za
Registered Linux User No: 371874
Office L15 Enterprise Building
The Innovation Hub - Hotel Street
Lynnwood, Pretoria, 0087
