Swig version used for nightly builds and releases...
Umberto Nicoletti umberto.nicoletti at GMAIL.COM
Thu Feb 8 14:52:35 EST 2007
1.3.29 is already used to build ms4w, so I think we should align with
them (or them with us ;-) ).
Plus 1.3.21 won't build Java mapscript because of enum support that
was added with 1.3.24.
I have built Java mapscript with all versions of swig from 1.3.28 up
to 1.3.31 without problems.
Umberto
On 2/8/07, Daniel Morissette <dmorissette at mapgears.com> wrote:
> Steve Lime wrote:
> > Hi all: Is there any reason I shouldn't upgrade the swig version on the
> > cvs machine from 1.3.21 to 1.3.29? It's
> > used to pre-build bindings for folks. I'd like to add C# but it
> > requires the newer version of Swig. Personally I
> > use 1.3.29 all the time with perl and some python with no problems, not
> > sure about java though.
> I don't use SWIG much myself, but if 1.3.29 works better then I think
> now is a good time to upgrade and agree on a new "official" version that
> everyone should try to use.
> Daniel
> Daniel Morissette
> http://www.mapgears.com/
