exporting layers to OGC interfaces
Paul Ramsey pramsey at REFRACTIONS.NET
Wed Feb 21 13:40:12 EST 2007
In order to retain current behavior, the absence of the keyword should
be equivalent to "all", and there should be a "none".
P
Frank Warmerdam wrote:
> Bart van den Eijnden (OSGIS) wrote:
>> Hi list,
>> I think there has been talk about this for several years now.
>> Currently there is no way to keep a LAYER from appearing in the
>> GetCapabilities output from a OGC service.
>> I think it was suggested in the past to adapt the DUMP keyword for this.
>> How about using a METADATA tag called ows_export which would have the
>> following possible values:
>> 1. all
>> 2. wms
>> 3. wfs
>> 4. wcs
>> 5. sos
>> or any combination of 2-5. The default value would be all, i.e. the
>> current
>> behaviour.
> Bart,
> Should we add an explicit none or would "ows_export" "" mean none?
>> The only thing which needs adapting then is checking for the value of
>> ows_export in the GetCapabilities output code (for all of the OGC
>> services
>> that Mapserver supports) or not?
> I think this sounds like a good idea and you should write up an RFC on the
> matter.
> Best regards,
   Paul Ramsey
   Refractions Research
   http://www.refractions.net
   pramsey at refractions.net
   Phone: 250-383-3022
   Cell: 250-885-0632
