exporting layers to OGC interfaces
Paul Ramsey
pramsey at REFRACTIONS.NET
Thu Feb 22 11:31:40 EST 2007
Daniel Morissette wrote:
> This specific one is an easy fix and will be easy to document in a 5.0
> migration guide. We could even make the GetCapabilities for disabled
> protocols spit out an exception explaining that protocol WXS is not
> enabled in this server, check the ows_export setting, etc.
I think that's key. If it is very clear what the problem is and how to
fix it, users are being treated with respect. So if I do
SERVICE=WFS&REQUEST=GETCAPABILITIES and I get a Capabilities with no
layers and a big comment saying "ows_export is not set" that helps a lot.
(I recently spent an enjoyable afternoon doing a binary search on some
SQL code (does this half of the code work on its own? how about this
half? how about this quarter?), because the Oracle error message was
"ambiguous column name". Had the Oracle folks simply told me which
column they *thought* was ambiguous I could have fixed it in 45 seconds,
instead of 90 minutes.)
P
Paul Ramsey
Refractions Research
http://www.refractions.net
pramsey at refractions.net
Phone: 250-383-3022
Cell: 250-885-0632
