Label Cache Performance
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Tue Jan 2 14:05:56 EST 2007
Yup, the bbox (or bpoly) used for annotation (w/markers) and curved
labels
is really just a multi-part polygon. We'd need to be able to render
those in
the byte/bit cache though.
Steve
>>> Paul Spencer <pspencer at dmsolutions.ca> 1/2/2007 12:55:37 PM >>>
This would need to work for 'curved' labels too. Would it work to do
things per-character?
Paul
On 2-Jan-07, at 12:40 PM, Steve Lime wrote:
> Remember also that you're not dealing strictly with bounding boxes
> (e.g.
> rects) but
> actual polygons whenever rotation is applied. This is so you get
> relatively tight fits
> around labels and can cram labels on a map.
>>>> Stephen Woodbridge <woodbri at swoodbridge.com> 1/2/2007 10:25:49 AM
> Steve Lime wrote:
>> Interesting idea. No, it's not been looked at before, not by me
>> anyway. Frank might have some thoughts on performance. You'd still
>> have to loop through the affected area to find collisions but I
> think
>> your correct in that the search time would basically be constant
>> (affected slightly by the size of the label).
>> Wouldn't be that hard to implement. I wonder if GD holding the
cache
>> image could be useful or if a custom 2-D bit array would be faster-
>> probably the latter...
> I thin a 2-D bit array would be much faster and require
significantly
> less memory, but would require writing a little additional code. The
> upside to this is that the code could be optimized for this specific
> task, unless there are other potential uses for this.
> Another idea I had related to this scheme would be that you could
> implement a function could search for a placement position withing
> some
> number of pixels. Here the idea would be that you use the polygon to
> create a mask and see if the mask collides, if not you are done,
> otherwise you do a spiral search outwards from the anchor point for
> some
> number of pixels looking for a place the label will fit. This is
easy
> to
> do in some nested loops and very fast.
> This idea of a moving mask is fundamental to a lot of the raster
> manipulation algorithm and is easy to implement and very fast to
> execute.
> -Steve W
>> Steve
>>>>> Stephen Woodbridge <woodbri at SWOODBRIDGE.COM> 1/2/2007 9:46:46
>>>>> AM
>> HNY All,
>> Last year I spent a fair amount of time optimizing a bunch of
>> mapfiles
>> for performance. One of the areas that seems to always be a
>> performance
>> hog if processing the Label Cache. I have been successful are
>> thinning
>> down the number of labels going into the cache, but I wondering if
>> there might be a more efficient way of dealing with it. Since I
have
>> been playing with rasters over the holidays I was wondering if it
>> might be possible to implement the label cache as a bitmap mask and
>> us a raster
>> OP to see if there is a collision?
>> OK, I'm sure it is possible, I guess my real question(s) are:
>> Has this approach been looked at before? Any thoughts on
> performance?
>> My idea is:
>> 1) create an label cache image 2) to check a label, get its bbox
>> polyon check if it overlaps and set pixels 3) polygon fill the bbox
>> of a label into the label cache image when a label is rendered
>> we might be able to use a 2:1 or 4:1 reduced size label cache image
>> with some thought about how to work around the issues.
>> I would think that this would be much faster than searching a list
> of
>> drawn labels and checking for intersections. And it should be
> linear
>> with the number of labels in the cache.
>> -Steve
|Paul Spencer pspencer at dmsolutions.ca |
|Chief Technology Officer |
|DM Solutions Group Inc http://www.dmsolutions.ca/ |
