Label Cache Performance
ROBERT HOLLINGSWORTH
reh2 at PRODIGY.NET
Wed Jan 3 11:42:10 EST 2007
> Last year I spent a fair amount of time optimizing a
> bunch of mapfiles
> for performance. One of the areas that seems to
> always be a performance
> hog if processing the Label Cache....
quick thoughts on subject:
* worked on an overlap prevention scheme back in 90s,
did rectangle comparison in two stages: first, compare
orthogonal bounding rectangle for the candidate
against same ortho rect for placed entities (in this
case, text and non-text objects). A positive collision
test may be case where two objects are rotated and the
ortho rect contains much white space (i.e., a false
positive). If that occurs, then compare the tightly
fitting rotated rectangles, which is a more expensive
computation, but not necessary unless the orthos have
collided.
* any thoughts on creating an index scheme so that
collision detection is only performed "in the
neighborhood" of the candidate placement? Maintaining
this, with a crude tile scheme or the more advanced
quadtree approach, can be more expensive than it's
worth unless the number of entities is past a certain
threshold.
REH
