KML output format?
Denis Nadeau denis.nadeau at GMAIL.COM
Thu Jan 4 16:18:18 EST 2007
I have been working here at the NASA DISC to implement a kml file that calls
MapServer WMS for Tropical Rainfall hourly data.
ftp://disc2.nascom.nasa.gov/data/TRMM/Gridded/Hurricane_Maps/Archive/KMZ_files/trmm-3B42-NRT.kmz
(kmz is only a zipped kml file.)
"That file links to a reflector (cgi-script) which is called each time the
camera stop and refreshing Google Earth with a new map.
 An interesting point is that Google Earth passes the BBOX to the reflector.
As mentionned in previous mesages, version GE 4.0 Beta now support WMS
GetCapabilities request. (ADD->Image Overlay->Refresh->WMS parameter)
I don't think the amount of work involve to create a basic KML driver will
be much.
I have done a lot of works with google earth lately,  if you need some input
let me know.
Denis
2007/1/4, Daniel Morissette <dmorissette at mapgears.com>:
> Bart van den Eijnden (OSGIS) wrote:
> > Right, we recently used Geoserver a lot to do this and it is excellent
> > functionality to have. We were thinking about having KML for Mapserver,
> > since we use Mapserver a lot more than Geoserver. How much
> > funding/co-funding are you thinking about Daniel?
> Actually the initial request I got for this came from someone who is in
> the same situation as you: a long time user MapServer who saw it done in
> GeoServer and wanted it in MapServer too.
> With respect to how much funding, I don't know yet. I am fairly new to
> KML and am not exactly clear yet on the amount of work involved.
> However, as usual, we could probably do something quick to support the
> most common use case for a few k$ and if we have more funding then we
> could add more bells and whistles.
> Daniel
> Daniel Morissette
> http://www.mapgears.com/
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20070104/a003b9c4/attachment.html
