Label Cache Performance
Stephen Woodbridge woodbri at SWOODBRIDGE.COM
Tue Jan 9 16:10:47 EST 2007
Steve Lime wrote:
> Too bad our hash implmentation doesn't allow an arbitrary value (e.g.
> void *) per key. Looks like
> it's char *'s.
Bummer! So is this a show stopper?
Can we cast another pointer into a char *?
Seems like this is an opportunity to improve our hash implementation so
it can be used by other pieces of the code. Or we could just use the GNU
system has routines.
And label_drawn_1 below probably needs to be a struct or array of the
pixel x,y where the label was drawn so it can be used for the distance
calculation.
-Steve W
> Steve
>>>> Stephen Woodbridge <woodbri at SWOODBRIDGE.COM> 1/8/2007 2:09:26 PM
> Steve,
> The hash key for say
> 	"Main St" => Array(label_drawn_1, label_drawn_2, ..]
> We only need to remember the the items that were actually drawn on the
> map since these are the only ones that need to be compared against when
> considering a potentially new label.
> Since the MINDISTANCE test is localized to a LAYER and possibly a CLASS
> modifying the key to include just the CLASS will suffice, like
> "<class_num>:<label_text>". The hash would be created for each layer
> and
> then disposed and recreated for the next layer. This is ok because
> MINDISTANCE does not span LAYERs unless I am mistaken.
> So here is pseudo-code for how this might work. Obviously there are
> details omitted and this would be implemented to be efficient. My goal
> here is to express the concept:
> for each layer {
>      if MINDISTANCE {
>          hash = create_hash()
>      } else {
>          hash = NULL;
>      for each label {
>          if (mindistance_ok(this.label, hash) &&
>              label_fits(this.label, bitmap)) {
>              # assumes it will update hash
>              draw_label(this.label, hash, bitmap)
> mindistance_ok() returns true if hash == NULL
> label_fits() compares the label polygon to the bitmap and returns true
> if it fits
> draw_label() renders the label and updates the hash if it is not NULL
> and updates the bitmap.
> I can expand the pseudo-code for mindistance_ok() and label_fits() is
> needed, but it seems that we should agree in principal that this will
> work for all existing cases. I have not heard any case that this can
> not
> be easily adapted to support.
> Steve - Does this cover the case you were concerned about? If not can
> you explain the scenario a little better, because I'm missing it.
> -Steve
> Steve Lime wrote:
>> Was thinking about this more and don't think a hash for MINDISTANCE
> will
>> work since
>> the hash keys need to be unique and label/class/layer certainly
> isn't.
>> You might have
>> 50 occurances of the same label for a series of road segments. I'm
> sure
>> there's a
>> workaround but it would undoubtedly be complex...
>> Steve
>>>>> Stephen Woodbridge <woodbri at SWOODBRIDGE.COM> 1/3/2007 9:35:26 PM
>> Steve Lime wrote:
>>> We use the loops for MINDISTANCE because we obviously are already
>> doing
>>> so for collisions.
>>> I thought about a hash too. Trouble is it's based not solely on the
>>> label text, but
>>> also class and layer indexes. For example you wouldn't want to
> ommit
>> a
>>> road
>>> label 'Washington' because of it's proximity to 'Washington' lake.
>>> Those types of
>>> situations are not all that rare...
>> Sure, but if you do the bitmap collision detection and use the hash
> for
>> MINDISTANCE, the hash would only exist while you are processing a
>> single
>> layer and then get dumped and a new hash created for the next layer.
> If
>> you need to keep hash entries unique by CLASS also, then you could
>> either create an array of hashes and index by classnum or have a
> single
>> hash and prefix ot postfix the keys with the class like
>> "classnum:key".
>> This should be very straight forward and I think very, very fast
>> compared to the way it works now. I'm sure there are other little
>> adjustments that would need to be made, but I can't think of any show
>> stoppers.
>> -Steve
>>> Steve
>>>>>> Stephen Woodbridge <woodbri at SWOODBRIDGE.COM> 1/3/2007 12:14:06
> PM
>>> If I were dealing with the MINDISTANCE issue in Perl I would create
> a
>>> hash where the key was the label text, because that is what
>> MINDISTANCE
>>> is restricting, and make the hash value an array of locations. This
>>> would much faster than any search algorithm and you would narrow
> the
>>> search to the array of placed text items of the same name.
>>> There is no reason this approach could not be used for the
>> MINDISTANCE
>>> case in mapserver. Using this and the bitmap collision detection
>> should
>>> remove most of the overhead of the label cache processing and make
> it
>>> very scalable with respect to number of items to be processed.
>>> -Steve
>>> Steve Lime wrote:
>>>> I did think of one other gotcha. The cache is not just used for
>>> physical
>>>> overlap, there
>>>> are other tests applied. For example, MINDISTANCE, which filters
>> out
>>>> like labels based
>>>> on proximity. That requires direct comparison of the bounding
>>> polygons.
>>>> One might be
>>>> able to reduce that to a test on label points (in fact that might
>> be
>>>> what's there now,
>>>> I'd have to check) but that still requires traversing placed
> labels
>>>> (albeit only those
>>>> within a particular layer)...
>>>> Steve
>>>>>>> Stephen Woodbridge <woodbri at swoodbridge.com> 1/2/2007 1:27:47
> PM
>>>> Yes, it works for all cases. You have to think about the problem
> as
>> a
>>>> raster problem not a vector or character problem.
>>>> So you do this by creating an image the size of rectangular bbox
> of
>>> the
>>>> label. Then you render the the character or label polygons boxes
>> into
>>>> the image. The image now becomes a mask representing the pixels of
>>>> where
>>>> the label will fall if it was rendered.
>>>> the test: Logical AND this mask image with the map label image
>> given
>>>> its
>>>> position in that image. You have a collision on the first AND
>> result
>>>> the
>>>> it true.
>>>> to update the map label image, just OR this label mask with the
> map
>>>> label image given its position in that image.
>>>> if you want to test another location, ie: you are searching for an
>>>> location nearby that the label will fit, then change the position
>> by
>>> a
>>>> pixel and repeat the test. This is more costly than just a test,
>> but
>>> is
>>>> still pretty efficient. I don't think you would want to apply this
>> to
>>>> every label, but having it as an option for a layer might be
>>>> interesting. You could constrain this to say search up/down or
>>>> right/left 10 pixels and then something like lot labels could
>> easily
>>> be
>>>> staggered. This is just an idea and it might not farm out to be
>>> useful,
>>>> but once the machinery is in, it falls out as a simple variation
> on
>>> the
>>>> theme.
>>>> -Steve
>>>> Paul Spencer wrote:
>>>>> This would need to work for 'curved' labels too.  Would it work
> to
>>> do
>>>>> things per-character?
>>>>> Paul
>>>>> On 2-Jan-07, at 12:40 PM, Steve Lime wrote:
>>>>>> Remember also that you're not dealing strictly with bounding
>> boxes
>>>> (e.g.
>>>>>> rects) but
>>>>>> actual polygons whenever rotation is applied. This is so you get
>>>>>> relatively tight fits
>>>>>> around labels and can cram labels on a map.
> 10:25:49
>>>> AM
>>>>>> Steve Lime wrote:
>>>>>>> Interesting idea. No, it's not been looked at before, not by me
>>>>>>> anyway. Frank might have some thoughts on performance. You'd
>>> still
>>>>>>> have to loop through the affected area to find collisions but I
>>>>>> think
>>>>>>> your correct in that the search time would basically be
> constant
>>>>>>> (affected slightly by the size of the label).
>>>>>>> Wouldn't be that hard to implement. I wonder if GD holding the
>>>> cache
>>>>>>> image could be useful or if a custom 2-D bit array would be
>>>> faster-
>>>>>>> probably the latter...
>>>>>> I thin a 2-D bit array would be much faster and require
>>>> significantly
>>>>>> less memory, but would require writing a little additional code.
>>>> The
>>>>>> upside to this is that the code could be optimized for this
>>>> specific
>>>>>> task, unless there are other potential uses for this.
>>>>>> Another idea I had related to this scheme would be that you
> could
>>>>>> implement a function could search for a placement position
>> withing
>>>> some
>>>>>> number of pixels. Here the idea would be that you use the
> polygon
>>>> to
>>>>>> create a mask and see if the mask collides, if not you are done,
>>>>>> otherwise you do a spiral search outwards from the anchor point
>>> for
>>>>>> some
>>>>>> number of pixels looking for a place the label will fit. This is
>>>> easy
>>>>>> to
>>>>>> do in some nested loops and very fast.
>>>>>> This idea of a moving mask is fundamental to a lot of the raster
>>>>>> manipulation algorithm and is easy to implement and very fast to
>>>>>> execute.
>>>>>> -Steve W
>>>>>>> Steve
>>>>>>>>>> Stephen Woodbridge <woodbri at SWOODBRIDGE.COM> 1/2/2007
> 9:46:46
>>>>>>>>>> AM
>>>>>>> HNY All,
>>>>>>> Last year I spent a fair amount of time optimizing a bunch of
>>>>>>> mapfiles
>>>>>>> for performance. One of the areas that seems to always be a
>>>>>>> performance
>>>>>>> hog if processing the Label Cache. I have been successful are
>>>>>>> thinning
>>>>>>> down the number of labels going into the cache, but I wondering
>>> if
>>>>>>> there might be a more efficient way of dealing with it. Since I
>>>> have
>>>>>>> been playing with rasters over the holidays I was wondering if
>> it
>>>>>>> might be possible to implement the label cache as a bitmap mask
>>>> and
>>>>>>> us a raster
>>>>>>> OP to see if there is a collision?
>>>>>>> OK, I'm sure it is possible, I guess my real question(s) are:
>>>>>>> Has this approach been looked at before? Any thoughts on
>>>>>> performance?
>>>>>>> My idea is:
>>>>>>> 1) create an label cache image 2) to check a label, get its
> bbox
>>>>>>> polyon check if it overlaps and set pixels 3) polygon fill the
>>>> bbox
>>>>>>> of a label into the label cache image when a label is rendered
>>>>>>> we might be able to use a 2:1 or 4:1 reduced size label cache
>>>> image
>>>>>>> with some thought about how to work around the issues.
>>>>>>> I would think that this would be much faster than searching a
>>> list
>>>>>> of
>>>>>>>  drawn labels and checking for intersections. And it should be
>>>>>> linear
>>>>>>>  with the number of labels in the cache.
>>>>>>> -Steve
>>>>> |Paul Spencer                          pspencer at dmsolutions.ca
>>>>> |Chief Technology Officer
>>>>> |DM Solutions Group Inc                http://www.dmsolutions.ca/
