RFC-24 Mapscript memory management: call for comments
Tamas Szekeres
szekerest at GMAIL.COM
Fri Jan 19 05:49:29 EST 2007
2007/1/19, Steve Lime <Steve.Lime at dnr.state.mn.us>:
> Seems like most of the issues are related to not knowing who (e.g. Swig
> or a mapObj)
> owns an object. It seems that if we removed ambiguity there then that
> would really
> help and you wouldn't have to touch the Swig stuff much.
> That is:
> - use dynamically allocated arrays of layers, classes and styles
> - then change insert functions to take ownership of objects to be
> inserted (I assume
> this is much easier with a list of pointers) (the insert sets parent
> pointer)
> - with that change wouldn't the deconstructors work "as is"? That is,
> ok to free
> if parent is NULL?
At the C side, if the parent is treated as the owner of the child, the
parent should not be destroyed until there are valid references to the
childs at the target language. In this regard, there's much more
things to do so as to implement this concept correctly. Currently the
greatest deal is to notify the wrapper when owner of the object (being
responsible to destroy the underlying memory) changes.
Steve,
Reading this thread, I can see a general disapproval of treating the
problems at the various target languages rather than trying to modify
the C side of the code somehow. It would be quite an easy to handle
the memory management uniquely at the C side without the need of
discovering the various aspects of a particular interface.
IMO, to implement this concept the lifespan of the C structures and
the corresponding wrappers at the target language should be decoupled.
Roughly speaking an additional property holding the number of
references should be added to every structures being exposed to the
SWIG interface, and the target language should notify the structure
about the release of this reference. Here are my steps to implement
this kind of functionality:
1. Use dynamically allocated objects (arrays of layers, classes and
styles) instead of nested structures.
(Using nested structures would predestinate the parent as owner of the
memory of the object)
2. Add a refcount member to every structure to be exposed to the
target language (the initial value is =1)
3. Alter the destroy logic of the structures. The structure should
only be destroyed when the reference count reaches zero, like:
void msFreeMap(mapObj *map) {
if(!map) return;
if (--map->refcount > 0) return;
// destroying the object as usual
4. Change the wrappers to consider every object is self-owned ensuring
that the C destroy function will be called when the wrapper object is
garbage collected and destroyed. To acieve this, the followings should
be done:
a, %newobject should be added to every members returning object
references.The functions should increment the refcount of the
corresponding structure.
b, When the structures have object reference members to be exposed to
the SWIG interface (like the reference to the mapObj at the layerObj),
the members should be replaced with the corresponding getters/setters.
These accessors should increment the refcount on the structure.
(potential backward incompatible change)
c, At the member functions taking over the objects passed as
parameters (like insertLayer) should increment the refcount of the
object parameter.
5. When a parent is destroyed the back references of the childs to
this parent should be set to null.
Some other things might also be considered.
Best Regards,
Tamas
