Access Control in MapServer
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Tue Jan 23 10:57:13 EST 2007
> Daniel Morissette wrote:
> > Sean Gillies wrote:
> >> Daniel, one word:
> >> Middleware, baby.
> >> Okay, two words. Your customer's access control
> requirements are probably going to be continually evolving,
> so keeping access control out of MapServer means easier
> development and maintenance. And it keeps a lot of
> complicated logic (needed by very few) out of the MapServer
> application itself.
> > Steve Lime wrote:
> >> I guess you can't do that level of access control outside of
> >> MapServer can you. I ok with this even if it's not terribly high
> >> priority personally.
> >> ACCESS...END
> > Some level of access control can be done outside of
> MapServer, but not
> > everything. For instance WMS layer level restrictions are easy to
> > implement in a wrapper that simply checks the LAYERS=...
> parameter of
> > a WMS request and denies the request if an unauthorized
> layer is requested.
> > However, things like attribute or bbox filtering can hardly be done
> > outside of MapServer, e.g. users from group X can only
> access features
> > from layer L that match expression "AUTH_GROUP = X", or users from
> > group Y can only access features inside a given BBOX or
> that intersect
> > with a given polygon.
> > Of course one could create separate layers for each class
> of users and
> > then simply do layer-level access control in a wrapper. That's the
> > kind of workarounds they use now, but when the number of
> > users/groups/restrictions combinations increase, the number
> of layers
> > become harder to manage and they are looking for something more
> > integrated and more powerful.
> > Daniel
> Daniel, I finally took a close look at DACS, and it doesn't
> seem so bad.
> It is middleware and has an Apache module. If you really have
> to implement super fine grain permissions into feature access
> and rendering, it might be a decent choice, but are you not
> worried about the performance hit of checking permission for
> every feature drawn on a map? Thousands of calls to the
> access control API for every map drawn?
> Decent performance is going to mandate pre-processed
> shapefiles or PostGIS views, so attribute-level run-time
> access control seems less useful the more I think about it.
> Am I having an olfactory hallucination, or do I smell GeoDRM
> around here? ;)
Another issue is that the DACS piece would have to be more neutral
w.r.t. platform and web server, to support Windows and IIS type
installs.
..Tom
