style level transparency
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Fri Jul 6 08:46:45 EDT 2007
Normand Savard wrote:
> Yewondwossen Assefa wrote:
>> Hi all,
>> One of the target feature for the 5.0 release was the support of
>> style or class level transparency (at least for GD based formats).
>> I had a brief discussion with Steve and after some tests that Steve
>> did, my understanding is that this feature can only be supported when
>> the output is a 24bit image and we wont be able to support it with the
>> current approach for 8 bit images.
>> Do people feel that this feature is worth for consideration even with
>> this limitation ?
>> Thanks,
> Do you think the support of style or class level transparency will make
> it for MS 5.0 release?
Not sure. I know that there is an opacity parameter in the style
object but I think it is not yet used.
> Norm
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
