Projections
Paul Spencer
pspencer at DMSOLUTIONS.CA
Sun Jul 8 22:17:03 EDT 2007
You need what is commonly referred to as EPSG:41001, defined as:
<41001> +proj=tmerc +ellps=WGS84 +units=m +no_defs <>
To use this, add the above line to your 'epsg' file and also add a
projection object to your map object:
PROJECTION
"init=epsg:41001"
END
You will also need to make sure that every layer in your map file has
a proper projection so mapserver can reproject it correctly.
Cheers
Paul
On 8-Jul-07, at 9:44 PM, Bradley Mclain wrote:
> This is kind of hard to explain but what I want to do is use
> Mapserver to project my data which is in the GDA94 projection as
> shown below:
> "# GDA94 / MGA zone 55
> <28355> +proj=utm +zone=55 +south +ellps=GRS80
> +towgs84=0,0,0,0,0,0,0 +units=m +no_defs <>"
> to a projection that will be able to be properly merged with Google
> maps (using OpenLayers) which uses a projection something like the
> following:
> "Update 4: Agreement frrom Melita Kennedy and David Burrows that
> Google Maps and Virtual Earth use spherical equations for the
> Mercator projection. The correct proj4 settings are:
> +proj=merc +latts=0 +lon0=0 +k=1.0 +x0=0 +y0=0
> +a=6378137.0 +b=6378137.0 +units=m
> Note this is different than using the ellipsoidal equations which
> would be:
> +ellps=WGS84 +datum=WGS84 +units=m no_defs"
> I believe that I need to use Mapserver to do this but I have no
> idea how to go about it. Currently my Mapserver is running fine
> displaying the data correctly using the GDA94 projection except i
> had to use a .vrt file to correctly align the raster image which
> was slightly out of alignment. I have also set up and can call my
> Mapserver as a WMS (thought having issues with the WMS Layer
> function in OpenLayers, just displays a white screen but I believe
> that this is to do with projections)
> My Mapserver has been compiled with GD, GDAL, GEOS, PostGIS, PHP
> and proj4.
> In my mapfile I have defined each layer using "init=epsg:28355" as
> well as globally defining the map using the same projection.
> This reason I am trying to do this is because currently I don't
> think that my projection can be properly imported into OpenLayers
> and merged with Google Maps.
> Thanks
> Brad
|Paul Spencer pspencer at dmsolutions.ca |
|Chief Technology Officer |
|DM Solutions Group Inc http://www.dmsolutions.ca/ |
