RFC 33: Removing msLayerWhichItems()...
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Fri Jul 13 12:26:08 EDT 2007
I have attributed the initial idea to Dan and instead Tamas made that post. Apologies...
Steve
>>> On 7/13/2007 at 10:57 AM, in message <46975A93.5157.008F.0 at dnr.state.mn.us>,
Steve Lime wrote:
> Dan made a comment somewhere in this thread about just modifying
> msLayerWhichItems() and I've
> been thinking about that and, as usual, I think he may have a good point. If
> you look at the code
> you might notice a little todo comment about requesting a list of all items
> first and then using them
> to build an item list. Functionally you end up with the same result but you
> know what you're looking
> for as opposed to having to look for it.
> So, what about adding a 'getall' flag to msLayerWhichItems()? If true you
> get 'em all but still build
> you're index relationships and expression item lists so no other code would
> have to be touched, except
> for the actual calls to the function. With getall=true the shapeObj's read
> later would be cachable for
> presentation. Drawing routines would want just the required attributes,
> queries would get all of 'em.
> msLayerWhichItems() would call msLayerGetItems() first and loop through that
> list. This should simplify
> the function. One other benefit is that regex grouping (e.g. [a|A] or
> [1..8]) would be allowed in logical
> expressions.
> Steve
> >>> On 7/12/2007 at 3:52 PM, in message <46964E4A.5157.008F.0 at dnr.state.mn.us>,
> Steve Lime <Steve.Lime at DNR.STATE.MN.US> wrote:
> > I'm starting to think this is a 5.2 change. It's definitely gnarly and the
> > effects are not understood
> > well enough...
> > Steve
> >>>> On 7/12/2007 at 1:08 PM, in message <46966E28.2050306 at mapgears.com>, Daniel
> > Morissette <dmorissette at MAPGEARS.COM> wrote:
> >> Steve Lime wrote:
> >>> The performance concern is real although I don't know how big a deal it is
> >> for all drivers. I
> >>> believe with shapefiles you get everything anyway. Not sure about others.
> >> How would OGR
> >>> be impacted?
> >> Your comment made me doubt so I ran both shapefiles and OGR data sources
> >> in the debugger and confirmed that when rendering a map, they both load
> >> only the attributes that are required.
> >> In the shapefile case I believe you still need to do the file I/O to
> >> read the full attribute record from disk, but only the values of the
> >> required attributes are strdup'd and stored in the shape->values[] array.
> >> OGR works in a similar way: the OGRFeature object returned by OGR
> >> contains all the attributes but we only copy the required attributes to
> >> the shape->values[] that is seen by MapServer.
> >> I think the performance gain/loss would be more significant for
> >> shapefiles than for OGR data sources for this reason.
> >>> msLayerWhichItems sets up the item indexes and you still need that for
> >> queries since CLASSes
> >>> come into play.
> >> Plus, OGR uses special item indexes for some special OGR attributes that
> >> are extracted from the style strings (OGR:LabelText, OGR:LabelAngle, and
> >> OGR:LabelSize), so if we get rid of item indexes we'll need to think of
> >> another way to handle that.
> >>> One way to mitigate the performance impact might be to allow a user to
> >> explicitly set the ITEMS
> >>> array in the configuration file. I'm hoping that with PostGIS and Oracle
> >> Spatial that's essentially
> >>> what you do with the sub-selects. An added benefit of that would be that
> >> inline features could
> >>> now have attributes:
> >>> LAYER
> >>> NAME 'anInlineLayer'
> >>> TYPE POLYGON
> >>> STATUS OFF
> >>> ITEMS name, type, area END
> >>> LABELITEM 'name'
> >>> FEATURE
> >>> POINTS ... END
> >>> VALUES 'St. Paul', 'CITY', '53045098.12' END
> >>> END
> >>> END
> >> I thought about providing the ability to specify the list of items in
> >> the layer as a possible solution as well, but then I realized that this
> >> was a move backwards for users since MapServer used to determine the
> >> list of items automatically, and from now on users would be required to
> >> do that manually for all layers if they care about performance.
> >> I find it odd for me to be arguing *for* keeping msLayerWhichItems()
> >> since I never really understood nor liked it until today. In the
> >> interest of getting this done for 5.0 and if everybody wants to get rid
> >> of it then I won't object any more. I'll be happy with an optional
> >> ITEMS...END block for those who really care about that little bit of
> >> performance.
> >> Daniel
