RFC-24 for symbolObjs is done
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Tue Jul 17 09:30:18 EDT 2007
Umberto Nicoletti wrote:
> Thanks Frank!
> Does this also fix the problem mentioned by Assefa?
Yes, the changes fixed the crash I was having. Thanks
> Thanks to all,
> Umberto
>> > As I promised last friday I have worked on symbolObjs to implement
>> > rfc-24 and now the code is in svn (rev. 6308).
>> > The code compiles cleanly (including mapscript and php), is memory
>> > leaks free (tested with valgrind) and runs the msautotest suite
>> > without errors (segfaults, that is).
>> > I have, as usual for RFC-24, added new tests to the refcount.py python
>> > test tuite.
>> > I still have to update the rfc page, I'll do that later.
>> Umberto,
>> I've made a few fixes in mapsymbol.c with failing to allocate
>> symbols in msAddImageSymbol() and msAddNewSymbol() in mapsymbol.c:
>> http://trac.osgeo.org/mapserver/changeset/6318
>> These were brought out by the msautotest/misc tests which demonstrated
>> a crash. It highlights our need for additional regression testing
>> for symbol services which is very thin right now.
>> Best regards,
>> I set the clouds in motion - turn up | Frank Warmerdam,
>> light and sound - activate the windows | http://pobox.com/~warmerdam
>> and watch the world go round - Rush | President OSGeo,
>> http://osgeo.org
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
