Build error on Mac OS...
Umberto Nicoletti umberto.nicoletti at GMAIL.COM
Thu Jul 19 04:34:29 EDT 2007
Applied.
I've modified the patch to initialize minVal and maxVal to avoid
compiler warnings.
Thanks,
Umberto
On 7/19/07, thomas bonfort <thomas.bonfort at gmail.com> wrote:
> here's the patch... I'm removing the dependency on maxfloat as it wasn't
> even necessary
> Umberto, could you apply it please, as you seem to be the only one awake
> here ;)
>  On 7/19/07, Umberto Nicoletti <umberto.nicoletti at gmail.com > wrote:
> > On my linux system include <values.h> is resolved to a file in
> /usr/include.
> > The header of the file says:
> > /* This interface is obsolete.  New programs should use
> >    <limits.h> and/or <float.h> instead of <values.h>.  */
> > Seems like we need one more configure check.
> > Umberto
> > On 7/19/07, Steve Lime <Steve.Lime at dnr.state.mn.us> wrote:
> > > Hi all, getting:
> > > mapchart.c:30:20: values.h: No such file or directory
> > > mapchart.c: In function `msDrawBarChart':
> > > mapchart.c:144: error: `MINFLOAT' undeclared (first use in this
> function)
> > > mapchart.c:144: error: (Each undeclared identifier is reported only once
> > > mapchart.c:144: error: for each function it appears in.)
> > > make: *** [mapchart.o] Error 1
> > > What is values.h part of cause I don't have it...
> > > Steve
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20070719/46f4be6b/mapchart-maxval.bin
