loadexpression : running into problems
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Wed Jul 25 09:28:35 EDT 2007
Thanks. Tested and it works as expected.
Steve Lime wrote:
> Found the problem and fixed it. It goes back to the original parse mapfile from string commit. (rev 6388)
> Steve
>>>> Yewondwossen Assefa <assefa at dmsolutions.ca> 07/24/07 12:48 PM >>>
> Steve Lime wrote:
>> How recent a version? I didn't touch the expression code, nor the lexer in that area. At least, I
>> don't think I did. Umberto made some changes as described in https://trac.osgeo.org/mapserver/ticket/2123
>> that possibly could have an impact.
> Mapserver from svn today.
>> Test data would help and I'll look into it asap.
> I will prepare the test case and send it to you
> Thanks
>> Steve
>>>>> On 7/24/2007 at 10:19 AM, in message <46A61899.2010607 at dmsolutions.ca>,
>> Yewondwossen Assefa <assefa at dmsolutions.ca> wrote:
>>> Hi Steve,
>>> I am running into problems with OGC Filters and recent builds of
>>> MapServer. I am doing something like:
>>> msLoadExpressionString(&lp->class[0]->expression,
>>> szExpression);
>>> szExpression =("[NAME]" = "Digby")
>>> in loadExpressionString function
>>> if((exp->type = getSymbol(4,
>>> MS_EXPRESSION,MS_REGEX,MS_IREGEX,MS_ISTRING)) returns -1 for this
>>> expression.
>>> Could it be related to recent changes ? If necessary I can provide
>>> map/data/url for testing.
>>> Thanks
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
