MapServer 5.0.0-beta1 tagged in SVN
Stephen Woodbridge woodbri at SWOODBRIDGE.COM
Wed Jul 25 13:56:45 EDT 2007
Cool, Thanks guys!
Here is an initial set of problems from the current svn:
http://mt2.imaptools.com/cgi-bin/mapserv-4.99?MAP=%2Fu%2Fdata%2Fmaps%2Fgoogle-agg.map&LAYERS=all&MAP_IMAGETYPE=agg%2Fpng24&MODE=map&SRS=EPSG%3A4326&mapext=-87.678065%2041.829507%20-87.622506%2041.87316&imgext=-87.678065%2041.829507%20-87.622506%2041.87316&map_size=700%20550&imgx=350&imgy=275&imgxy=700%20550
1) AGG does not seem to be anti-aliasing, look at the roads in this image
2) mapserver does not seem to be honoring the image size request in the
CGI params above
woodbri at carto:/u/software/mapserver-SVN/mapserver$ ./mapserv-4.99 -v
MapServer version 5.0.0-beta1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER INPUT=EPPL7
INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
You want bugs opened on these?
-Steve
Daniel Morissette wrote:
> I have tagged 5.0.0-beta1 in SVN a few minutes ago as
> https://svn.osgeo.org/mapserver/tags/rel-5-0-0-beta1/mapserver/
> Frank and Jeff, you are welcome to make builds available of that version
> when you have a chance.
> Finally, I do not have access to the machine where the releases are
> packaged. Is this still done on the UMN machine or is this done on the
> OSGeo servers now? Could Steve/Frank please either give me access, or
> just package and post the source package themselves at the usual location?
> Once the packages are available I will send a note about this to
> mapserver-users.
> Thanks
> Daniel
