[PATCH] WCS reprojection problem fix
Daniel Morissette dmorissette at MAPGEARS.COM
Thu Jul 26 10:41:04 EDT 2007
Frank Warmerdam wrote:
> Even Rouault wrote:
>> (I've posted a previous message yesterday, but doesn't seem to have
>> found its way through the mailing list...)
>> Here's a patch for 2 things :
>> * fix for a few minor memory leaks in WCS server
>> * fix a quite annoying bug that was explained by Jérôme Martin (see
>> the original thread :
>> http://lists.umn.edu/cgi-bin/wa?A2=ind0702&L=mapserver-users&T=0&F=&S=&P=852)
> Evan,
> Could you submit these patches via Trac?  Daniel is pretty strict about
> having bugs associated with commits now that we are into beta season.
> It might make sense to submit two bugs, one per issue, if they are
> distinct.
FYI I had found and fixed the leak of gdIOCtx in mapgd.c in V4.99 (SVN
trunk) but there was no ticket and the fix was not backported to the
4.10 branch:
http://trac.osgeo.org/mapserver/changeset/6273
Daniel
Daniel Morissette
http://www.mapgears.com/
