SVN issue
Daniel Morissette
dmorissette at MAPGEARS.COM
Fri Jul 27 15:55:34 EDT 2007
Steve,
Can you please retest this with 5.0-beta1? While working on RFC-17 I
have found and fixed a few issues that may have led to this kind of
problem. If the issue is still there in the latest code then please file
a ticket and assign to me (Trac id=dmorissette) and I'll have a look.
Daniel
Stephen Woodbridge wrote:
> Hi all,
> I am getting a segv using svn revision 6257.
> In the following layer, if class_color is commented out, I get a segv.
> This worked fine on previous versions. I'm fine with a requirement that
> this change and is noted in MIGRATION_GUIDE.TXT, but we should not segv.
> LAYER
> NAME "US_States_Annotation"
> STATUS DEFAULT
> DATA "us/states"
> TYPE ANNOTATION
> MINSCALE 4000100.0
> LABELITEM "STATE"
> LABELCACHE OFF
> CLASS
> COLOR 0 0 0
> LABEL
> FONT "arial-bold"
> TYPE TRUETYPE
> POSITION CC
> SIZE 9
> BUFFER 4
> COLOR 150 150 150
> PARTIALS FALSE
> MINDISTANCE 250
> MINFEATURESIZE 10
> END
> END
> END
> -Steve W
Daniel Morissette
http://www.mapgears.com/
