source code layout and organization
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Wed Jun 6 01:04:47 EDT 2007
Typically one runs configure from the top level directory so Makefile.in, configure.in and so
on should probably live there along with the high level docs. I don't know where it makes
sense to create lib and bin directories. Creating in svn simplifies the Makefile a bit.
I like the idea myself but don't sense a lot of interest from others...
Steve
>>> "Kralidis,Tom [Burlington]" <Tom.Kralidis at EC.GC.CA> 05/29/07 1:21 PM >>>
How about:
mapserver
bin/ (the output binaries)
lib/ (libmap.a, anything else?)
src/
mapscript/
tests/
- I'm guesssing bin/ and lib/ would not be part of the svn, rather
created when building?
- could README and INSTALL live in the root, and config files, etc. live
in src/?
..Tom
> > mapserver/
> > etc/
> > core/
> > formats/
> > mapscript/
> > ogc/
> > tests/
> > util/
> I'd be very interested in code cleanup, but like Frank
> stuffing things into directories doesn't seem that
> beneficial. I guarantee there are grey areas, for example,
> where do you put something like mapgml.c, ogc or formats?
> I'd be more interested in a structure like:
> mapserver/
> lib/
> bin/
> include/ (?)
> src/
> tests/
> mapscript/
> So at least after a build the binaries are separated from the
> source code. All the configuration files, READMEs and
> HISTORY.txt would live in the top level directory.
> As for code clean-up, besides those already mentioned. 1) The
> msObj definition is a mess in maptemplate.h (I think I
> created a bug for that already) and 2) mapimagemap.c has a
> lot of leftovers from it's original coding.
> Steve
> >>> On 5/29/2007 at 8:14 AM, in message
> <2576812186CDD411BF1500508B6DCE9511B30E9D at ecnwri1.ontario.int.
> ec.gc.ca>,
> "Kralidis,Tom [Burlington]" <Tom.Kralidis at EC.GC.CA> wrote:
> > Hi,
> > Does anyone have comments w.r.t. the organization of the
> codebase into
> > something more palatable? For example:
> > mapserver/
> > etc/
> > core/
> > formats/
> > mapscript/
> > ogc/
> > tests/
> > util/
> > This would be much easier now that MapServer is svn'd.
> > This would also provide the opportunity to do a once over against
> > files in the codebase (i.e. mapprojhack.c might deserve a more
> > appropriate filename, or using mapmygis.c when MapServer
> can use OGR
> > for VRT style and spatial connections).
> > Any comments?
> > ..Tom
