Thoughts on a feature cache for queries...
Umberto Nicoletti umberto.nicoletti at GMAIL.COM
Wed Jun 6 02:54:05 EDT 2007
On 6/6/07, Steve Lime <Steve.Lime at dnr.state.mn.us> wrote:
> Hi all: What would folks think about implementing a simple feature cache for storing query results? I know Tamas has something grander planned but it seems a ways off and implementation with queries may be problematic anyway. We could use the featureList structures that form a linked list containing shapeObj's. I've always been a bit hesitant to do this because with large datasets you could use a ton of memory, but the performance bottlenecks with the two-pass query probably out weigh that problem. If folks are somewhat positive about the idea I'd be glad to work up an RFC...
> Steve
Wouldn't this be quite similar to storing query results in a separate
layer which I think was discussed not long ago?
Umberto
