Mapserver Memory Leak #2
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Thu Jun 7 23:31:00 EDT 2007
Using msyylex_destroy would be preferable over the homegrown cleanup function
in maplexer.l. I can do this, will you file a ticket?
Steve
>>> Stephen Woodbridge <woodbri at SWOODBRIDGE.COM> 06/07/07 7:48 PM >>>
It looks like the maplexer.c might be leaking memory.
maplexer.c:4318 (current svn) allocates yy_buffer_stack and this is
getting leaked.
It should probably get freed in lexer_cleanup() with something like:
if( (yy_buffer_stack) != NULL )
msyyfree( (yy_buffer_stack) );
(yy_buffer_stack) = NULL;
or by calling
msyylex_destroy();
or by something similar. I am not familiar with this code so someone
that knows it should probably look into this and verify that my
assumptions are correct.
Thanks,
-Steve W
