[Fwd: Re: [MapServer] #2120: Memory Leak in msSetup()]
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Sat Jun 9 19:12:30 EDT 2007
Howard,
Sorry can you change this again. See below.
Also did you add msyylex_destroy();
This breaks things as the function is not declared.
Thanks,
-Steve
-------- Original Message --------
Subject: Re: [MapServer] #2120: Memory Leak in msSetup()
Date: Sat, 09 Jun 2007 23:07:36 -0000
Reply-To: trac at osgeo.org
To: undisclosed-recipients:;
References: <047.b6bf82e29a47a4f0f84f40105361bd34 at osgeo.org>
Reporter: woodbri | Owner: sdlime
Type: defect | Status: new
Priority: normal | Milestone: 5.0 release
Component: MapServer C Library | Version: 5.0
Severity: normal | Resolution:
Keywords: |
Comment (by woodbri):
Howard,
Sorry, my bad. The patch should be as msCleanup() does not return a value.
#ifdef USE_GD_FT
gdFontCacheShutdown();
#endif
Ticket URL: <http://trac.osgeo.org/mapserver/ticket/2120#comment:2>
MapServer <http://mapserver.gis.umn.edu>
