MS RFC 22a: Feature cache for long running processes and
query processing (C
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Tue Jun 12 13:13:40 EDT 2007
I'll bite off smaller chunks for more discussion. Comments inline...
>> How would do you see configuration of a capability like that? For example, a typical buffer operation would have a distance, perhaps units and maybe a corner tolerance.
> Any provider specific information would go into the metadata section
> of that layer. So in this case we could use the following definition
> example:
We also have the PROCESSING section that I wonder if might be more appropriate than METADATA. Frank uses it as a mechanism to define raster processing parameters and already has access routines available. Would be nice to be consistent regarding configuration as new processors become available.
> LAYER
> CONNECTIONTYPE BUFFEROPERATION
> METADATA
> "distance" "23"
> "units" "meters"
> END
> LAYER
> CONNECTION "any other layer"
> END
> END
> I would also allow to specify the operation parameters as feature items, like
> METADATA
> "distance" "[distanceitem]"
> END
> The most trivial implementation of this buffer provider is to allow
> only the nested layer specification and propagate every vtable
> functions to the inner layer. The operation should be applied on the
> features retrieved by the NextShape and GetShape calls respectively.
So this could be used in a non-caching environment without issue then?
Steve
