MS RFC 22a: Feature cache for long running processes and
query processing (C
Tamas Szekeres
szekerest at GMAIL.COM
Tue Jun 12 14:46:34 EDT 2007
2007/6/12, Steve Lime <Steve.Lime at dnr.state.mn.us>:
> I'll bite off smaller chunks for more discussion. Comments inline...
> >> How would do you see configuration of a capability like that? For example, a typical buffer operation would have a distance, perhaps units and maybe a corner tolerance.
> > Any provider specific information would go into the metadata section
> > of that layer. So in this case we could use the following definition
> > example:
> We also have the PROCESSING section that I wonder if might be more appropriate than METADATA. Frank uses it as a mechanism to define raster processing parameters and already has access routines available. Would be nice to be consistent regarding configuration as new processors become available.
Generally I have no problem with this. However it's more performant to
retrieve the values from the hashtable rather than from a string
array.
> > LAYER
> > CONNECTIONTYPE BUFFEROPERATION
> > METADATA
> > "distance" "23"
> > "units" "meters"
> > END
> > LAYER
> > CONNECTION "any other layer"
> > END
> > END
> > I would also allow to specify the operation parameters as feature items, like
> > METADATA
> > "distance" "[distanceitem]"
> > END
> > The most trivial implementation of this buffer provider is to allow
> > only the nested layer specification and propagate every vtable
> > functions to the inner layer. The operation should be applied on the
> > features retrieved by the NextShape and GetShape calls respectively.
> So this could be used in a non-caching environment without issue then?
Yes, absolutely
Tamas
