MS RFC 22a: Feature cache for long running processes and
query processing (C
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Tue Jun 12 17:16:45 EDT 2007
We'd have to retrieve parameters for each feature processed unfortunately. Too bad the PROCESSING block isn't
a hash itself...
Steve
>>> On 6/12/2007 at 1:46 PM, in message
<f3b73b7d0706121146s69a7ebf0la50bcfa011dfb642 at mail.gmail.com>, Tamas Szekeres
<szekerest at GMAIL.COM> wrote:
> 2007/6/12, Steve Lime <Steve.Lime at dnr.state.mn.us>:
>> I'll bite off smaller chunks for more discussion. Comments inline...
>> >> How would do you see configuration of a capability like that? For example,
> a typical buffer operation would have a distance, perhaps units and maybe a
> corner tolerance.
>> > Any provider specific information would go into the metadata section
>> > of that layer. So in this case we could use the following definition
>> > example:
>> We also have the PROCESSING section that I wonder if might be more
> appropriate than METADATA. Frank uses it as a mechanism to define raster
> processing parameters and already has access routines available. Would be
> nice to be consistent regarding configuration as new processors become
> available.
> Generally I have no problem with this. However it's more performant to
> retrieve the values from the hashtable rather than from a string
> array.
>> > LAYER
>> > CONNECTIONTYPE BUFFEROPERATION
>> > METADATA
>> > "distance" "23"
>> > "units" "meters"
>> > END
>> > LAYER
>> > CONNECTION "any other layer"
>> > END
>> > END
>> > I would also allow to specify the operation parameters as feature items,
> like
>> > METADATA
>> > "distance" "[distanceitem]"
>> > END
>> > The most trivial implementation of this buffer provider is to allow
>> > only the nested layer specification and propagate every vtable
>> > functions to the inner layer. The operation should be applied on the
>> > features retrieved by the NextShape and GetShape calls respectively.
>> So this could be used in a non-caching environment without issue then?
> Yes, absolutely
> Tamas
