draw a layer with labels but no pointsymbols
Hallgren Johan E
jhhal at WMDATA.COM
Wed Jun 13 09:24:32 EDT 2007
I have had some troubles drawing a layer only with labels, and no
points. I hade to use an empty STYLE-tag (see below), otherwise the
image wasn't generated.
It's a bit strange to use an empty tag in that situation, and it was
hard to find the problem.
These two examples works:
LAYER
NAME "31"
TYPE POINT
DATA "C:\TEMP\SVEASKOG\data\PPL_TRK_P.shp"
STATUS OFF
CLASS
TEXT '8'
LABEL
COLOR 255 0 0
TYPE TRUETYPE
FONT Verdana
SIZE 18
END
STYLE
END
END
END
LAYER
NAME "32"
TYPE POINT
FEATURE
POINTS
100 100
END
END
TRANSFORM false
STATUS ON
CLASS
TEXT '8'
LABEL
COLOR 255 0 0
TYPE TRUETYPE
FONT Verdana
SIZE 18
END
STYLE
END
END
END
But not these
LAYER
NAME "31"
TYPE POINT
STATUS OFF
CLASS
TEXT '8'
LABEL
COLOR 255 0 0
TYPE TRUETYPE
FONT Verdana
SIZE 18
END
END
END
LAYER
NAME "32"
TYPE POINT
FEATURE
POINTS
100 100
END
END
TRANSFORM false
STATUS ON
CLASS
TEXT '8'
LABEL
COLOR 255 0 0
TYPE TRUETYPE
FONT Verdana
SIZE 18
END
END
END
/Johan
___________________________________
Johan Hallgren
WM-data a LogicaCMG company
Pelle Bergs backe 3
Box 1938, 791 19 Falun
Tel: 023-547 46 (int: +46-2354746)
Mobil: 070-588 44 28 (int: +46-705884428)
johan.e.hallgren at wmdata.com
<BLOCKED::mailto:johan.e.hallgren at wmdata.com>
http://www.wmdata.se
<BLOCKED::/exchweb/bin/redir.asp?URL=http://www.wmdata.se/>
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20070613/b0de4b3c/attachment.html
