[Fwd: Re: [UMN_MAPSERVER-DEV] Re-thinking RFC 6]
Jan Hartmann
j.l.h.hartmann at UVA.NL
Fri Jun 15 09:13:38 EDT 2007
Perhaps converting the start and end color to HSV (Hue, Saturation,
Value) would give values that could be interpolated in a meaningful way.
For display, the interpolated colors could be converted back to RGB. The
algorithm is elementary, i believe.
Jan
Daniel Morissette wrote:
> Interesting idea. I think I like it, but I'm not sure if I might not be
> missing some possible drawbacks of it.
> Back to RFC-6 itself, one problem I've always had with it is that doing
> linear interoplation of RGB values between (r1, g1, b1) and (r2, g2, b2)
> doesn't necessarily give a good looking color ramp. Others with more
> experience dealing with colors than me could better comment, but I think
> you'd almost need a color lookup table, or have the ability to specify
> multiple r,g,b points that define a path in the RGB space instead of
> just the start and end point.
> Daniel
> Steve Lime wrote:
>> I agree on the naming. Will have to ponder that. I'd like an syntax
>> that would accommodate colors and numbers in the same way:
>> PARAMETERLIMITS #FFFFFF #FF0000 or PARAMETERRANGE 1 10
>> (we can handle that in mapfile.c) and then
>> ITEMLIMITS 1000.0 50000.0
>> or something like that.
>> The machinery is very similar to that of RFC 19, you just use a
>> msBindLayerToRange function that works just like msBindLayerToShape
>> (same parameters even). Most of the plumbing is in maputil.c already,
>> as is the original range code Bill Binko wrote.
>> Steve
>>>>> Frank Warmerdam <warmerdam at POBOX.COM> 06/14/07 11:18 PM >>>
>> Steve Lime wrote:
>>> Hi guys: As the deadline for RFC's approaches I wanted to float a
>>> change to RFC 6 that might be doable by 5.0. I've not spent time
>>> updating the RFC yet. The idea would be to bind properties to ranges
>>> much like RFC 19. We'd extend the range concept to colors, sizes and
>>> angles. So COLORRANGE would become RANGE. RANGEs would live at the
>>> layer level and would be referenced by name so you could have several.
>>> A range would be defined as:
>>> typedef struct {
>>> char *name;
>>> attributeBindingObj item; /* holds name and index */
>>> colorObj mincolor, maxcolor; /* only colorObj's and numbers make
>>> sense */
>>> double minnumber, maxnumber;
>>> double minvalue, maxvalue;
>>> int intervals;
>>> int method; /* should be enum - MS_RANGE_METHOD */
>>> } rangeObj;
>>> and a layer would have an array (fixed size, might be ok, should need
>>> more than a couple, or dynamic) of these.
>>> Styles properties (color, outlinecolor, size, angle) could then
>>> reference these by name.
>>> e.g.
>>> LAYER
>>> NAME 'myLayer'
>>> RANGE
>>> NAME 'sizeRange'
>>> ITEM 'sizeitem'
>>> MINNUMBER 1
>>> MAXNUMBER 10
>>> MINVALUE 1000.0
>>> MAXVALUE 500000.0
>>> END
>> Steve,
>> I sort of like this approach though it seems like substantial
>> machinery might be needed to support it.
>> I also really think that you need to make it more clear what are
>> input values and what are output values. Perhaps min_in_val,
>> max_in_val, min_out_scalar, max_out_scalar. For me "value" and
>> "number" are too general to work out which is input and output
>> of the function.
>> Best regards,
