MS RFC 28: Redesign of LOG/DEBUG output mechanisms
Frank Warmerdam
warmerdam at POBOX.COM
Fri Jun 15 15:41:12 EDT 2007
Daniel Morissette wrote:
> Hi Dev's,
> I have prepared a first version of MS RFC 28 that proposes a cleanup of
> the LOG/DEBUG output mechanisms while keeping things simple (I like
> simple) and not breaking too much existing code:
> http://mapserver.gis.umn.edu/development/rfc/ms-rfc-28
> Comments welcome... and expect two more RFCs from me today...
Daniel,
I like it.
I am somewhat conflicted about "DEBUG ON" not being enough to enable
actual debug output. I think it is unfortunately that this and the
MS_ERRORFILE setting will be required. I'd suggest that we should have
MS_ERRORFILE default to "stderr" which is roughly the behavior now for
msDebug() if built into the binaries. But then we are likely to have a
lot of error noise showing up in the logs that perhaps does not belong.
Keeping the error file handle in the error context should address
multithreading just fine as I believe you and Tamas have already
concluded.
I like Tamas' idea of an MS_ERROFILE windowsdebug option on windows.
Potentially we could offer a syslog option on unix that is roughly
analygous though I don't feel any compelling need for this.
I would be happy to review the raster related msDebug() calls and set
appropriate error levels.
I assume that DEBUG=MSDEBUG will disappear from the version string, since
debugging will always be compiled in?
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
