MS RFC 22a: Feature cache for long running processes and
query processing (update)
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Tue Jun 26 13:47:52 EDT 2007
Re: 2), yes, I like the idea of geometry expressions. The expression syntax probably could
be extended to operate on a shape (e.g. buffer(centroid(this), 10)). Don't know how well
that fits with the nested layer concept though. It would probably make more sense as a
single layer parameter, e.g.:
GEOPROCESS 'buffer(centroid(this), 10)'
Personally I'm comfortable with a 'provisional' or 'experimental' tag in 5.0...
Steve
>>> On 6/26/2007 at 10:24 AM, in message <46812FC9.10304 at pobox.com>, Frank
Warmerdam <warmerdam at POBOX.COM> wrote:
> Tamas Szekeres wrote:
>> According to our recent IRC conversation we would rather keep the
>> state of the cache preserved across the various sessions and map
>> creations. I think if the in-process state preservation is sufficient
>> than it could be easily handled inside the caching provider.
>> However it seems that the existing connection pooling mechanism cannot
>> be utilized for this purpose since the preserved objects are
>> distinguished based on the connection parameter and it cannot serve
>> the same object for different threads.
>> To implement this kind of functionality I could imagine taking out the
>> cache related parameters into a separate struct and use a global
>> hashtable to store the various cache state instances. The user should
>> explicitly specify which instance should the layer use. For example:
>> PROCESSING "cache_instance=cache1"
>> Where "cache1" is the key to get the cache state from the global hashtable.
>> The provider would use the necessary locks when accessing the global
>> cache, and msCleanup would destroy the cache when the process
>> terminates.
> Tamas,
> I'm concerned about thread safety issues if a single cache is being
> used by multiple threads at the same time. Are you planning on fine
> grained locking around each request for a shape from the cache?
> Basically, I think fully thread-shared cache access is going to be
> dangerous and should not be implemented.
> That aside, the connection pooling approach is still not suitable
> because the CONNECTION string for stuff like CACHE layers is not
> a very unique name. We could just modify the pooling API so that
> the "connection" name is passed in. Then for CACHE layers this
> could be some more unique name. Alternatively we could just declare
> that folks wanting long lived caches (presumably using the usual
> PROCESSING "CLOSE=DEFERRED" line) should take great care to use
> unique layer names in their CONNECTION string.
>> IMHO, however, it would be highly beneficial to establish a common
>> support for the long term state preservation in mapserver. Any of the
>> providers could push objects into a common repository and mapserver
>> would be responsible to free up the objects when the process
>> terminates.
> I'm not sure I see the other applications of this.
> BTW, I have finally reviewed the whole of RFC 22a, and generally I
> am quite impressed. A few concerns:
> 1) I wish there were specific sections in the RFC giving detailed
> docs for each of the new data providers (CACHE, LAYERFILTER and
> GEOMTRANS I believe). I am left with a vague sense that I'm not
> seeing all the layerfilter and geomtrans operators by scanning
> the examples.
> 2) I am nervous about the "introduced language" for describing
> geometry filtering operations. I'd be inclined to make this
> particular provider unofficial for 5.0 with the understanding
> that we might want to overhaul the syntax for 5.2. In particular
> I wish we had a more functional (perhaps Simple Features for SQL-like)
> syntax for geometry operations.
> 3) I have a nervous sense that nested layers are going to cause us
> unexpected problems.
> 4) How are nested layers manipulated in mapscript? I'd like to see
> this addressed in the RFC.
> I expect to be in formal support of this RFC when it is brought to vote
> though I'm hoping for some clarification on the above points and I'm
> not in favor of a cache shared between threads without very careful
> analysis of the impact.
> Best regards,
