MS RFC 22a: Feature cache for long running processes and
query processing (update)
Frank Warmerdam
warmerdam at POBOX.COM
Wed Jun 27 14:37:04 EDT 2007
Daniel Morissette wrote:
> If I understood the RFC correctly, the proposed solution to this problem
> will be to embed all layers inside a CACHE wrapper layer, correct? So by
> default all postgis/oracle/sde/etc connections will still suffer from
> the double-pass query problem unless we add the CACHE layer around them,
> right? This adds an additional thing that users needs to be aware of in
> order to tune their app.
Daniel,
I share this concern. Essentially that we have put the onus
on the user to setup a cache layer to get queries working
at a reasonable speed instead of treating this internally
as I had originally proposed.
> - What does nesting do if the outer layer is not of connection type
> cache, layerfilter or geomtrans? For instance what happens if I have a
> layer of type point (shapefile) which contains two nested layers of type
> point?
I believe nested layers that are not addressed by their parent or some
other layer would never be used for anything, wouldn't show up in
WMS layer lists, etc.
> - With respect to STYLEITEM AUTO the plan is to cache the class objects
> for each shape? Won't that be expensive for large layers?
I had this concern too, though it isn't clear to me what else could
be done. I trust we will only pay this class object penalty when
styleitem auto is in effect.
> I feel bad for raising all those issues since you seem to have put quite
> a bit of hard work on this, and would need to put even more work to
> implement it. It also seems that everybody else likes the proposal, so
> hopefully it's just me who's not "getting it"... and in this case please
> show me the light. :)
My conservative side feels very much the same. The complexity frightens
me, and yet I don't want to be too negative after all the effort Tamas
has put in.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
