Call for vote on MS-RFC-28: LOG/DEBUG output mechanism
Jeff McKenna
jmckenna at DMSOLUTIONS.CA
Fri Jun 29 15:04:13 EDT 2007
Daniel Morissette wrote:
> This is what you get if you only set DEBUG ON at the map level. If you
> set DEBUG on in some (or all) layers as well then you'll get more info
> specific to each layer. What kind of info you get in this case depends
> on each layer type.
Yes i am aware of that (i saw this message coming from you saying that,
I must be psychic ha). But this is a valid example of a user trying to
get more info on drawing times.
Let's leave it at that and go ahead with the RFC.
jeff
