AGG support
Vincent Schut
schut at SARVISION.NL
Mon Mar 12 06:34:40 EDT 2007
Hi all,
Always eager to try new stuff, I decided to try the agg rendering. Not
surprisingly (no offense :-)) I get a serviceException from my mapserver
WMS service:
<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
<!DOCTYPE ServiceExceptionReport SYSTEM
"http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd">
<ServiceExceptionReport version="1.1.1">
<ServiceException code="InvalidFormat">
msWMSGetLegendGraphic(): Image handling error. Unsupported output format
(image/png).
</ServiceException>
</ServiceExceptionReport>
This is of course using a WMS request that does work when I replace the
agg outputformat with my original GD one.
I have defined the outputformat in my map file as follows (the commented
lines are the original GD png outputformat which works, so you can
compare it with the AGG one):
# OUTPUTFORMAT
# NAME png_rgba
# DRIVER "GD/PNG"
# MIMETYPE "image/png"
# IMAGEMODE rgba
# TRANSPARENT on
# EXTENSION "png"
# #FORMATOPTION interlace=on
# END #outputformat
OUTPUTFORMAT
NAME png_rgba
DRIVER "AGG/PNG"
IMAGEMODE RGBA
TRANSPARENT on
EXTENSION "png"
END
As I said, I am using mapserver cgi as WMS.
Any clues how to get the new outputformat recognized by mapserver WMS?
Vincent.
John Novak wrote:
> Tom,
> Please do provide input on your experiences with the new AGG code,
> Best,
> John Novak
> On 3/9/07, *Steve Lime* < Steve.Lime at dnr.state.mn.us
> <mailto:Steve.Lime at dnr.state.mn.us>> wrote:
> Use at your own peril, but you can certainly play with it. John
> Novak has done the bulk of the work to date
> with new input coming from Assefa. It looks promising so many
> thanks for the excellent work to date.
> I don't believe there are extensions to the Windows Makefile but I
> did commit configure support for *nix
> yesterday. Works fine on my SuSE box. Just do a --with-agg=path to
> agg when running configure and
> it should work. You need agg version 2.4 at this point. Agg
> doesn't have install scripts so I just left it
> where I built it ( e.g. /usr/local/src/agg-2.4). Configure will
> look for that type of setup or in the system libs.
> To use simply plop a OUTPUTFORMAT in your mapfile like so:
> OUTPUTFORMAT
> NAME myAggRgb
> DRIVER AGG/PNG
> IMAGEMODE RGB
> END
> RGB and RGBA are supported.
> The AGG driver uses GD as the buffer manager, so basically AGG
> renders to a GD image so we can use GD
> file writing and any of the other GD writing code. That allows us
> to concentrate on pieces of the rendering
> while still creating complete images. At the moment I believe
> polygons and lines are rendered using AGG
> while markers and text fallback on their GD counterparts.
> Steve
> >>> On 3/9/2007 at 1:36 PM, in message
> <2576812186CDD411BF1500508B6DCE9511B30C88 at ecnwri1.ontario.int.ec.gc.ca
> <mailto:2576812186CDD411BF1500508B6DCE9511B30C88 at ecnwri1.ontario.int.ec.gc.ca>>,
> "Kralidis,Tom [Burlington]" < Tom.Kralidis at EC.GC.CA
> <mailto:Tom.Kralidis at EC.GC.CA>> wrote:
> > Just noticed mapagg.cpp in CVS HEAD.
> > Is / can this be tried out? Any build details?
> > ..Tom
> John Novak
> Novacell Technologies and the Old Topo Depot
> http://www.novacell.com
> 877-old-topos
