RFC-24: published implementation proposal on bugzilla
Tamas Szekeres szekerest at GMAIL.COM
Thu Mar 15 16:13:26 EDT 2007
Umberto,
Currently I cannot see the exact match between the actual
implementation and the proposal described in rfc24.
Additionally I feel that this implementation is incomplete as it stands now.
Here are some raisings about the changes (without ranking by the importance)
1. The changes affecting the target language code is mostly missing.
In one hand you can force the ownership at the wrapper using the
%newobject feature like:
%newobject getLayer;
  layerObj *getLayer(int i) {
    if(i >= 0 && i < self->numlayers) {
    	MS_REFCNT_INCR(self->layers[i]);
      	return (self->layers[i]); /* returns an EXISTING layer */
    } else {
      return NULL;
but this philosophy is not reflected by some other functions returning
objects as:
layerObj *getLayerByName(char *name) {
    int i;
    i = msGetLayerIndex(self, name);
    if(i != -1)
    else
      return NULL;
