ALPHACOLOR_ENABLED code in mapfile.c
Paul Spencer pspencer at DMSOLUTIONS.CA
Fri Mar 23 20:11:27 EDT 2007
Would there be any benefit for the AGG work?  I can't think of any
reason, just asking :)
Paul
On 23-Mar-07, at 4:05 PM, Daniel Morissette wrote:
> We've been reminded in bug 2052 (http://mapserver.gis.umn.edu/bugs/
> show_bug.cgi?id=2052) that there is some unused code in mapfile.c
> and a few other files dating from 2003 to add ALPHA to the
> ColorObj. This code is all inside #ifdef ALPHACOLOR_ENABLED but
> there is no documentation for this or any way to use this code
> without manually adding the flag to the makefiles (i.e. no
> configure options, etc.).
> Steve's suggestion in the bug, which I agree with is:
>> I haven't had any plans (or heard a good reason) to use alpha
>> channel values in colors. Rather I would support a style-level or
>> label-level opacity value that would serve that function and
>> impact all colors associated with an object. Doing so would
>> mitigate configuration confusion, would not require a change to
>> the colorObj (and all supporting code), and would keep
>> configuration in the mapfile straight forward.
>> Unless other complelling reasons exist (and they might) I would
>> just as soon remove all references to ALPHACOLOR_ENABLED...
> I'm sending this email to find out if anyone sees a need to
> maintain, complete and document this code to handle ALPHA in the
> ColorObj. If not then we'll remove the code and add style-level or
> label-level opacity to the TODO list as suggested by Steve.
> Daniel
> P.S. Please reply to mapserver-dev and not via the bug report. This
> question is off-topic for the bug which was just about a compile
> error and turned into a longer debate about the usefulness of this
> code.
> Daniel Morissette
> http://www.mapgears.com/
|Paul Spencer                          pspencer at dmsolutions.ca    |
|Chief Technology Officer                                         |
|DM Solutions Group Inc                http://www.dmsolutions.ca/ |
