request for comment: adding xslt processing to mapserver
Paul Spencer
pspencer at DMSOLUTIONS.CA
Sat Mar 24 17:25:34 EDT 2007
Sean,
do you have any suggestions on what might be used for new keywords?
At this point, I was planning to suggest using metadata to trigger it
just to avoid adding new keywords :)
Cheers
Paul
On 23-Mar-07, at 1:20 PM, Sean Gillies wrote:
> Paul Spencer wrote:
>> MapServer devs ...
>> DMSG has a contract with Environment Canada/Tom Kralidis to
>> implement some changes to the Sensor Observation Service.
>> Part of this contract is to write a technical report on the
>> feasibility of introducing the ability to transform XML coming out
>> of MapServer's various OGC interfaces (specifically WMS
>> GetFeatureInfo, WFS GetFeature and SOS GetObservation) using an
>> XSLT directly in MapServer. I (with help from Assefa) have
>> prepared a draft of this report structured more-or-less like an RFC.
>> One of the requirements is to 'gauge the reaction of the TSC to
>> this proposal', which is the purpose of this email. If the
>> general feedback from you is positive, I believe Tom will then
>> submit this as an RFC for approval and, if approved, will seek
>> funding to implement the changes.
>> Please give the attached proposal a read over and let me know:
>> * would you be for or against this capability being introduced
>> into mapserver?
>> * if against, would any rewording or additional detail change your
>> mind?
>> * is there enough technical detail in the proposal?
>> * is there anything obvious missing (I know I may have missed
>> some files that would need to be modified)?
>> * any other comments?
>> I know this is last minute, but the report is due for mid next
>> week so getting your feedback ASAP is highly desirable.
>> Cheers
>> Paul
> I like it :) I'd like it even more if this kind of application
> configuration was cleanly separated from the cartographic
> configuration -- new keywords instead of adding new powers to
> existing ones.
> Cheers,
> Sean
> Sean Gillies
> http://zcologia.com/news
|Paul Spencer pspencer at dmsolutions.ca |
|Chief Technology Officer |
|DM Solutions Group Inc http://www.dmsolutions.ca/ |
