More OracleSpatial queryByAttributes
Hallgren Johan E
jhhal at WMDATA.COM
Fri Mar 30 16:39:31 EDT 2007
I have tested more to isolate the problem.
Here is the MapFile
LAYER
NAME SDOLayer
TYPE POLYGON
STATUS OFF
CONNECTION "user/pwd at tnsname"
CONNECTIONTYPE oraclespatial
DATA "shape FROM SDOLayer USING UNIQUE objectid VERSION 10g"
TEMPLATE "c:\temp\template.txt"
STATUS DEFAULT
MAXSCALE 150000
DEBUG ON
CLASS
STYLE
OUTLINECOLOR 0 0 255
COLOR 255 0 0
END
END
END
Here is a samplecode.
mapObj mapObj = new
mapObj(@"C:\Project\applications\GMS\GMSAgent\MapFiles\Map.map");
layerObj oLayerObj = mapObj.getLayerByName("SDOLayer");
string orgDataStr = oLayerObj.data;
string tmpDataStr = oLayerObj.data;
int iUsingLocation = tmpDataStr.LastIndexOf(" USING ");
if (iUsingLocation > 0)
tmpDataStr = orgDataStr.Substring(0, iUsingLocation);
tmpDataStr += " USING NONE";
// CREATE ERROR.
// This is used to speed up the query, no spatial operator will be used.
oLayerObj.data = tmpDataStr;
string strFld = "OBJECTID";
string strWhere = "OBJECTID = 2000";
oLayerObj.queryByAttributes(mapObj, strFld, strWhere,
mapscript.MS_MULTIPLE);
oLayerObj.data = orgDataStr;
resultCacheObj oResultCacheObj = oLayerObj.getResults();
if (oResultCacheObj.numresults > 0)
int lFeat = 0;
oLayerObj.open();
for (lFeat = 0; lFeat < oResultCacheObj.numresults; lFeat++)
resultCacheMemberObj oResultCacheMemberObj =
oResultCacheObj.getResult(lFeat);
// ERROR - ERROR - ERROR - ERROR - ERROR - ERROR - ERROR - ERROR -
ERROR - ERROR
// HERE IS THE ERROR.
// oResultCacheMemberObj.shapeindex will always return the first
record. If the oLayerObj.data
// is not changed, the result is correct but the perforamce is
terrible.
shapeObj oShapeObj =
oLayerObj.getFeature(oResultCacheMemberObj.shapeindex,
oResultCacheMemberObj.tileindex);
for (int item = 0; item < oLayerObj.numitems; item++)
string strUFldName = oLayerObj.getItem(item).ToUpper();
if (strUFldName != "SHAPE")
string strVal = oShapeObj.getValue(item);
System.Diagnostics.Debug.Write(strUFldName + "=" + strVal + ",
System.Diagnostics.Debug.Write(Environment.NewLine);
System.Diagnostics.Debug.WriteLine("-------------------");
oLayerObj.close();
___________________________________
Johan Hallgren
WM-data a LogicaCMG company
Pelle Bergs backe 3
Box 1938, 791 19 Falun
Tel: 023-547 46 (int: +46-2354746)
Mobil: 070-588 44 28 (int: +46-705884428)
johan.e.hallgren at wmdata.com
<BLOCKED::mailto:johan.e.hallgren at wmdata.com>
http://www.wmdata.se
<BLOCKED::/exchweb/bin/redir.asp?URL=http://www.wmdata.se/>
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20070330/75a6f39d/attachment.html
