Release MapServer 4.10.2 on Friday?
Bart van den Eijnden (OSGIS)
bartvde at OSGIS.NL
Thu May 3 04:35:52 EDT 2007
I think the following bugs would also be good candidates to be backported
for 4.10.2:
http://trac.osgeo.org/mapserver/ticket/1925
http://trac.osgeo.org/mapserver/ticket/2079
http://trac.osgeo.org/mapserver/ticket/2082
http://trac.osgeo.org/mapserver/ticket/2084
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Daniel Morissette <dmorissette at MAPGEARS.COM>
Naar: MAPSERVER-DEV at LISTS.UMN.EDU <MAPSERVER-DEV at LISTS.UMN.EDU>
Onderwerp: [UMN_MAPSERVER-DEV] Release MapServer 4.10.2 on Friday?
Datum: 02/05/07 17:27
> There are a few good fixes waiting in the 4.10 branch. I propose that we
> release MapServer 4.10.2 with those fixes on Friday of this week.
> I start the vote with a +1.
> Daniel
> P.S. Here is the list of changes in 4.10 from the HISTORY.TXT:
> Version 4.10.2
> - Support for embedding manifests as resources for the VS2005
> builds.(bug 2048)
> - Changed OGRLayerGetAutoStyle not to pass NULL pointer to
GetRGBFromString
> causing access violation (bug 1950).
> - do not double-grab the row_id column in msSDELayerGetItems (bug 2041)
> - Apply patch for bug 1990 for OS X Framework builds support for Python
> MapScript. Thanks William!
> - Added missing MS_FOLLOW constant to PHP MapScript (bug 2058)
