More of pooling, mapquery.c
Andreas Albarello andreas.albarello at TERRITORIUMONLINE.COM
Mon May 7 06:25:59 EDT 2007
Hallgren Johan E wrote:
> Hello again,
> I have made a test with the following code with extremely good
> performance. I have only tested this specific call, but couldn’t the
> concept be implemented in other functions as well? As I see it, it will
> implement the Connection pool between mapscript calls.
Johan,
this shouldn't be necessary unless your connection pooling is not
working correctly. Mapserver's connection pool already successfully
shares connections having the same connection string within the same
thread. The msLayerOpen call in your example should therefore not be
opening another connection to the database.
If it indeed does, you might want to check if your connection pooling is
up and working, if it is active on that layer, that you have a fairly
recent Mapserver/Mapscript build and that the subsequent requests come
from within the same thread.
Best regards,
Andreas Albarello
Analysis & SW Development
Territorium Online srl/GmbH
Via Buozzi/Buozzistraße 12 - I 39100 Bolzano/Bozen
email: andreas.albarello at territoriumonline.com
web:   www.territoriumonline.com
