mapserver svn - AGG and PostGIS issues
Paul Spencer
pspencer at DMSOLUTIONS.CA
Mon May 7 14:37:46 EDT 2007
Steve, I've gone over everything again and the good news is that AGG
seems to be working (mostly) correctly.
And I think the postgis problem is actually an AGG problem related to
drawing filled vector symbols. Argh!
Paul
On 7-May-07, at 10:01 AM, Steve Lime wrote:
> Paul: Did you get any offline feedback? I don't really know what
> could cause #1 except
> that the ANTIALIAS token isn't being recognized. I'll check on that.
> #2 pre-dates SVN, any ideas folks????
> Steve
>>>> Paul Spencer <pspencer at DMSOLUTIONS.CA> 05/03/07 4:09 PM >>>
> Hi all,
> we've been trying to build mapserver trunk from SVN into an FGS
> module and have the following issues:
> 1. agg output no longer seems to be rendering using antialiasing -
> map draws but it doesn't appear to be doing any antialiased
> rendering. reverting to a cvs version from a week or so ago, it
> works. No apparent errors or anything (seems to work just fine
> except for the non-aa map).
> 2. postgis layers cause mapserver to segfault. I couldn't get
> debugging symbols into the fgs build for some reason, but I did see
> this in gdb: 0x0807fae9 in msOracleSpatialLayerGetShapeVT (). Any
> ideas? CVS version from a week ago has the same problem as this.
> Cheers
> Paul
> |Paul Spencer pspencer at dmsolutions.ca |
> |Chief Technology Officer |
> |DM Solutions Group Inc http://www.dmsolutions.ca/ |
