Zsort ?
Attila Csipa
plists at PROMETHEUS.ORG.YU
Thu May 17 11:28:36 EDT 2007
On Thursday 17 May 2007 17:01, Stephen Woodbridge wrote:
> So in the small result set, these could be sorted on the fly, but it
> would get a little convoluted to have an attribute index in combination
> with the spatial index. That would probably require having a spatial
> index for each attribute index to preserve the order of that index,
> which seems a little much.
Maybe I'm not correct, but as I outlined in the previous mail we could get
away with just one index per attribute + the spatial index. The index is
roughly a B+ tree, sorted by a given attribute (or even attribute
combinations). When we do the pass thorugh the spatial index, we have the IDs
of the items we need to draw. Using a hash these can be looked up quickly.
Now, we do a simple pass through our B+ tree, and discard every value that is
not in our hash, and remembering each one that is there. The result is a
subset of the attribute index which contains only the shape IDs that need to
be drawn _in the proper order_, no additional sorting or manipulation is
needed. This should not be a major performance issue unless the B+ tree or
the spatial hash have an excessively large number of nodes, in which case the
bottleneck would be probably reading all those shapes and attributes, and not
the extra tree/hash operations that need to be done to get the sort order
right.
