source code layout and organization
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Wed May 30 02:35:39 EDT 2007
I, like Frank, am -0 on this issue, but if we wanted to do this I'd
opt for TomK's layout
with lib and bin created at building time.
Umberto
On 5/29/07, Kralidis,Tom [Burlington] <Tom.Kralidis at ec.gc.ca> wrote:
> How about:
> mapserver
> bin/ (the output binaries)
> lib/ (libmap.a, anything else?)
> src/
> mapscript/
> tests/
> - I'm guesssing bin/ and lib/ would not be part of the svn, rather
> created when building?
> - could README and INSTALL live in the root, and config files, etc. live
> in src/?
> ..Tom
> > > mapserver/
> > > etc/
> > > core/
> > > formats/
> > > mapscript/
> > > ogc/
> > > tests/
> > > util/
> > I'd be very interested in code cleanup, but like Frank
> > stuffing things into directories doesn't seem that
> > beneficial. I guarantee there are grey areas, for example,
> > where do you put something like mapgml.c, ogc or formats?
> > I'd be more interested in a structure like:
> > mapserver/
> > lib/
> > bin/
> > include/ (?)
> > src/
> > tests/
> > mapscript/
> > So at least after a build the binaries are separated from the
> > source code. All the configuration files, READMEs and
> > HISTORY.txt would live in the top level directory.
> > As for code clean-up, besides those already mentioned. 1) The
> > msObj definition is a mess in maptemplate.h (I think I
> > created a bug for that already) and 2) mapimagemap.c has a
> > lot of leftovers from it's original coding.
> > Steve
> > >>> On 5/29/2007 at 8:14 AM, in message
> > <2576812186CDD411BF1500508B6DCE9511B30E9D at ecnwri1.ontario.int.
> > ec.gc.ca>,
> > "Kralidis,Tom [Burlington]" <Tom.Kralidis at EC.GC.CA> wrote:
> > > Hi,
> > > Does anyone have comments w.r.t. the organization of the
> > codebase into
> > > something more palatable? For example:
> > > mapserver/
> > > etc/
> > > core/
> > > formats/
> > > mapscript/
> > > ogc/
> > > tests/
> > > util/
> > > This would be much easier now that MapServer is svn'd.
> > > This would also provide the opportunity to do a once over against
> > > files in the codebase (i.e. mapprojhack.c might deserve a more
> > > appropriate filename, or using mapmygis.c when MapServer
> > can use OGR
> > > for VRT style and spatial connections).
> > > Any comments?
> > > ..Tom
